UCS QoS, VoIP applications and upstream switch
harrygranger
We have followings:
Chassis 5108
FI 6248
FEX 2208
Adapter VIC(1240), 2 vNIC for VMData (VoIP applications), a few others vNIC for mgmt, vmotion etc.
ESXi 5.1
CUCM, Unity, etc
For example, CUCM and Unity marked VoIP media as CoS 5 and signaling as 3.
Will FI overwrite all markings to CoS 5 if VMData vNIC QoS policy is created as platinum with host control FULL (see picture)?
In other words, will the upstream switch see the same QoS markings from VoIP applications?
Harry
Robert Burns
If you enable host control and enable COS 5, then yes the FI well overwrite the host assigned QOS.
Sent from Cisco Technical Support Android App
Hello Harry,
Here is a good link ondesign recommendations on QoS + UC ( VoIP apps ) + UCS
http://docwiki.cisco.com/wiki/QoS_Design_Considerations_for_Virtual_UC_with_UCS#Guidelines_for_Physical_LAN_Links.2C_Trunking_and_Traffic_Sizing
Padma
Thanks for the link. It was a very good read.We don't have n1k and will be using vswitch.
I hate to mark non-voip traffics to cs3. So we may have to leave QoS policy out for UC data since we have way more bandwith provision UC apps required.What a tough choice.
