I recently installed a new UCS s3260 and after providing it with power the chassis won't boot up, it usually boots up and all lights go green but this time the power button on the front of the chassis is amber and all other lights do nothing, usually there is activity
the Server blade is installed in slot 1 and it has power and the light turns green, I can use the Dongle to connect a KVM to it and see that it loads into post and bios - but no further, as it has no resources as the drives are attached to the chassis, I can not access CIMC of the Chassis. not sure if I'm missing something or if anyone has any ideas
the system was working at another location 2 weeks ago - it was then moved and to this location and now I have this issue - thanks in advanced!
