UCS Spec for Cisco Molding Labs 2.7
RajeewPerera
Hi There
I'm looking for a UCS Spec for Cisco Molding Labs 2.7 for 60 students to work simultaneously. looked for  days but could not find the spec for my requirement.
Any help is apricated
Thank you
ajagadee
Hi, You can look at the information in the below link along with "What resources are required by each node type?" and should be able to do the math based on your specific scenarios and needs.
https://developer.cisco.com/docs/modeling-labs/system-requirements/
https://developer.cisco.com/docs/modeling-labs/faq/#faq---cisco-modeling-labs-v2x
Arul
