UCS temperature sensor
Steve Warren
Is it possible to power off the UCS if the temperature sensor reading exceeds a certain value?
Can I power off the UCS remotely?
Robert Burns
Steve,
No.  The thresholds are not configurable.  This ensures we can set the thresholds according to manufacturing specs to ensure the HW is always protected.
regards,
Robert
Thanks Robert.  Will the UCS power off when this threshold is voilated?
Hello Steve,
UCSM will not auto shutdown the blades and it is left to CPUs to control the action based on inbuilt thermal characteristics.
You can remotely power down blades using IPMI commands.
https://supportforums.cisco.com/message/3625575#3625575
Padma
Thanks. I will do some reasearch on the IPMI commands.
