UCSPM 2.0 SSL Cert Replacement
Paul O'Leary
Anyone replaced the default ucspm.XXXXX SSL Certificate in a UCSPM 2.0 install?
I found the following on Zenoss, but the Cisco Docs have nothing to say about it:
How to configure SSL for Control Center and Zenoss 5.x to prevent browser untrusted connection error – Zenoss
Paul O'Leary
For those playing at home. Here's the openssl commands to make the key / csr.
I used an Active Directory PKI to make my 2048 cert and then the last openssl command to convert from p7b to cut:
openssl genrsa -out ucspm2.key 2048
openssl req -new -key ucspm.key2 -out ucspm2.csr
openssl pkcs7 -print_certs -in ucspm2.p7b -out ucspm2.cer
Used the console interface and pasted into Putty and no problem.
