Upgrading the FI and UCS chassis components from 3.1(1h) to 3.1(2e)
dganta
Hi Team,
I am planning to do an upgrade UCS infrastructure and the UCS servers from 3.1(1h) to 3.1(2e) using auto-installtion specifically for UCS manager and UCS FI. Would like to know whether there are any challenges or bugs I need to look for this upgrade.
Dinesh
Walter Dey
Hi Dinesh
If you or your customer is paranoid, I would open a TAC case, and ask for a impact analysis upgrading from 3.1(1h) to 3.1(2e).
However, I would be very optimistic, that this will be working without problems (only maintenance release change)
Walter.
Anarv Handoo
Hi Dinesh,
I would suggest you to open a TAC case for firmware upgrade pre-check.
Anarv
