Urgent Help required for UCS
ashjosh11
Hi Team ,
We added new Chassis into our exisitng UCS infrastructure.
We discovered Chassis also & gave IPs to CIMC of new servers also.
New Chassis IOM to FI cabling is also correct.
But when i am trying to communicate with CIMC of Servers, connecion is failed.
Also i installed OS manually on 1of the blade after creating service profile , OS IP is not able to ping & coomunicate iwth outer world.
Same Fabric interconnect , Same port channel , Same uplinks , OLD Chassis is working fine.
New chassis not able to communicate with outter world.
What can be the issue ? Am i missing something in configuration ?
WHt new chassis CIMC & BLADE IP is not able to ping & communicate.
padramas
Hello Ashish,
Let us focus on network connectivity to OS interface.
Make sure you have allowed necessary vlans in the vNIC defined in the Service profile.
Does FI server ports learning the MAC address of the server in the correct VLAN ?
connect nxos
show mac address table
Padma
Yes ,
All VLANs are correctly appearing in Service profile & MAC address are showing properly.
Scratching my head in this issue.
Please provide following output
show service-profile circuit server X/Y
   ===> X - Chassis  ; Y - server number
connect nxos
show mac address-table  | grep
