USB KEY in B-200M3
dani_bosch
I have a customer interested in acquiring UCS, but they have some USB HASP keys (for software protection) in their current physical environment and don't have clear how to connect these keys with new UCS blades AFTER a VMware P2V process. I've heard there are some solutions out there to provide remote access to these HASP USB Keys. Could you recommend me a solution?
Thanks a lot,
dani_bosch
Anyone having tried USB over the network?
http://www.usb-over-network.com
Jeremy Waldrop
Level 4
Level 4
I have had good luck using Digi AnyWhereUSB
http://www.digi.com/products/usb/anywhereusb
+1 to the AnywhereUSB. I use it for clustered virtual machines in VMware that have the same issue.
