VM-FEX and SR-IOV
Terry MacDougal
I am aware of the benefits as published in the literature about the benefits of VM-FEX and SR-IOV but would like some clarifications/opinione from anyone who is currently running this sort of setup.
OS: Windows 2012 hyper-v
UCSM: 2.1(2a)
I under the following:
SR-IOV is a specification that allows multiple VMs to share a single PCIe device correct?
In order to utilize this specification on Windows 2012 you have to enable/configure VM-FEX is UCSM correct?
This means you can't run VM-FEX on Windows 2012 without SR-IOV correct?
One is the specification and the other is the actual mechanism (VM-FEX) to achieve SR-IOV?
It essentially will by-pass the virtual switch in the parent partition, enabling traffic to be switched in the FIs, correct?
Thanks for any clarification.....
richbarb
That's right! the virtual machine network will be controlled by the UCS directly instead the Hyper-V virtual switch.
This is a good document to clarify this idea:
http://www.cisco.com/en/US/solutions/collateral/ns340/ns517/ns224/ns955/ns963/solution_overview_c22-687087.html
