VNIC's don´t have link connection on operating system
paulo.ferreira
Hello Everyone,
I'm configuring the UCS B-Chassis, and i'm having some problems with lan connectivity in all installed operating system.
All Interconnect LAN configuration seems fine, but the 2 NIC's on operating system don't have link connection.
In UCS Manager console i already check the DCE Interfaces and the Intel 10G NIC's configurations and they are in operable state.
Resuming, the UCS are all configured, but i don't have connectivity between Blades NIC's (eth0, eth1) and FEX's
Thank you in advanced
Paulo Ferreira
kar-wai.chin
try to set you 1st vnic to fabric A, and 2nd vnic to fabric B and enable auto fail over. After that, try to reset the connectivity on both fabric for the specified blade. You should have the uplink configured for Ethernet which I assumed.
Craig
http://malaysiavm.com
amcglown
Paulo,
     If your 61x0 is configured in End Host mode and you do not have any uplink ports that are active then the link to the blade OS will be down.
Andre McGlown
