vPC Speed in UCSM
Tom MacDonald
We currently have 2 10G FC connections going into each FI and a pair of Nexus 5K's (a total of 4 10G connections). This consists of our vPC and it is displaying an operational speed of 10G, should this not be 20G?
padramas
Hello Mike,
UCSM version ?
Can you please share the screen shot on where you notice the operational speed ?
Also, share the output of following command
connect nxos
show int port-channel
Padma
I would think the operational speed would be similar to our FC-port-channel trunk (32G with 4 FC connections).....
UCSM 2.1......
Screenshot attached.......
port-channel20 is up
  Hardware: Port-Channel, address: 547f.ee99.6e99 (bia 547f.ee99.6e99)
  Description: U: Uplink
  MTU 1500 bytes, BW 20000000 Kbit, DLY 10 usec,
  Encapsulation ARPA
  Port mode is trunk
  full-duplex, 10 Gb/s
  Beacon is turned off
  Input flow-control is off, output flow-control is off
  Switchport monitor is off
  EtherType is 0x8100
  Members in this channel: Eth1/17, Eth1/18
  30 seconds input rate 48 bits/sec, 6 bytes/sec, 0 packets/sec
  30 seconds output rate 136 bits/sec, 17 bytes/sec, 0 packets/sec
  Load-Interval #2: 5 minute (300 seconds)
    input rate 224 bps, 0 pps; output rate 304 bps, 0 pps
  RX
    8787 unicast packets  105340 multicast packets  38991 broadcast packets
    153118 input packets  18780359 bytes
    0 jumbo packets  0 storm suppression bytes
0 giants      0 input error  0 short frame  0 overrun   0 underrun      0 watchdog  0 if down drop
    0 input with dribble  0 input discard
    0 Rx pause
  TX
    0 unicast packets  55536 multicast packets  0 broadcast packets
    55536 output packets  13069769 bytes
    0 jumbo packets
    0 output errors  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble
    0 Tx pause
  2 interface resets
The following bug is fixed in 2.1.1a for the operational speed value displayed in GUI for ethernet port-channels.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCub47897
I just checked the lab device running 2.1.1a and it still shows 10 Gbps as operational speed value for upstream LAN port-channel
I would suggest you to open a TAC service request to further investigate this issue.
Padma
