webUI access problems
Ahmetyucemarble
I have a cisco c220 M3  server . I was change access WebUI port http and https. I did the same http and https. Now Not access.
How can I access?
Kirk J
Greetings.
Can you still ssh to the CIMC ip?
What CIMC firmware level are you running, and what ports did you change 80/443 to?
Can you still ping the CIMC IP address?
Kirk...
Yes, I have access to its SSH. I tries it now.
change port http:4343 and change https:4343
I did to following. I fix it with SHH. Thank you.
Server# scope http
Server /http # set enabled yes
Server /http *# set http-port 80
Server /http *# set https-port 443
Server /http *# set timeout 1800
Server /http *# commit
Server /http # show
HTTP Port  HTTPS Port Timeout  Active Sessions Enabled HTTP Redirected
4343       4343       1800     0               yes     yes
