What is the C240 M5 warning threshold max for fans set as NA?
Owk
Checking on CIMC, I realised that the warning threshold max value for fans on C240 M5s are set as NA. Is this intended if it is how can we monitor if the fan speed is spinning too fast?
Kirk J
Not all thresholds are used or set for every sensor.  Many of those apply more to CPU temps, PSUs, CMOS battery, etc
There is no negative impact to the system from a cooling perspective, if a fan is running 'faster' than some of it's peers.
NA just means there has been no value established and programmed.
Kirk...
Kirk J
Kirk...
