dsoper
Here's an overview of setting up a basic server environment on the UCS Platform Emulator using the Python SDK.  Portions of the script used in the video are provided below.  For more information on the emulator and the Python SDK please see the following:
Also, if you're headed to Cisco Live 2016 in Las Vegas, be sure to check out one of several sessions covering UCS Programmability and the Python SDK.  Here's a post with additional info: UCS Programmability at Cisco Live!
Script used in the video:
import csv
from ucsmsdk import ucshandle
from server import service_profile
from ucsmsdk.mometa.ls.LsRequirement import LsRequirement
if __name__ == "__main__":
    try:
        <snip>
        handle = ucshandle.UcsHandle(settings.ip, settings.user, settings.pw, secure=settings.secure)
        handle.login()
        apply settings from each row in the csv file
        csvFilename = sys.argv[1]
        csvFile = open(csvFilename, "r")
        if not csvFile:
            print "Error: could not open %s" % csvFilename
            sys.exit(1)
        csvReader = csv.DictReader(csvFile)
        rowNum = 1
        for row in csvReader:
            rowNum += 1
            if not row['template']:
                print "Error on row %d: no template name found" % rowNum
                continue
            template = row['template']
            profileName = row['profile']
            if not profileName:
                profileName = "%s-instance-" % template
            numInstances = int(row['instances'])
            if not numInstances:
                numInstances = 1
            print "Creating %s service profiles with name prefix %s" % (numInstances, profileName)
            parentDN = 'org-root'
            service_profile.sp_template_create(handle, name=template, type="initial-template",
                                               ident_pool_name=row['UUID'],
                                               parent_dn=parentDN)
            service_profile.sp_create_from_template(handle,
                                                    naming_prefix=profileName,
                                                    name_suffix_starting_number="1",
                                                    number_of_instance=numInstances,
                                                    sp_template_name=template,
                                                    in_error_on_existing="true",
                                                    parent_dn=parentDN)
            serverPool = row['Server-Pool'] if (row['Server-Pool']) else 'default'
            for instance in range(1, numInstances + 1):
                dn = "%s/ls-%s%d" % (parentDN, profileName, instance)
                mo = LsRequirement(parent_mo_or_dn=dn, restrict_migration="no",
                                   name=serverPool, qualifier="")
                handle.add_mo(mo, True)
                handle.commit()
        handle.logout()
    except Exception, err:
        print "Exception:", str(err)
        import traceback, sys
        print '-'*60
        traceback.print_exc(file=sys.stdout)
        print '-'*60
