4.0 UCS bundle
I am running Cisco UCS 5108 Chassis, 6248 FI, and B200 M4 blades in my environment. We just upgraded all the firmware to 3.2.3(j). Any reason to upgrade to the 4.0 bundle? What are advantages/fixes? I have read through the release notes and 4.0 just seems to add support for newer hardware. Is there something I'm missing here?
Wes Austin
There is really no reason to upgrade unless you are looking for feature updates or fixed bugs. We recommend being on the "starred" firmware release as it will have the most fixes and feature for that release train. (3.1.X, 3.2.X, etc)
Otherwise, if you are happy on the code you are on, no need to upgrade.
