03-01-2013 01:18 AM - edited 03-01-2019 10:54 AM
Hello
Having an HA issue with a FI cluster and have not able to find much info.
The error I get (in the subject) leads me the the below URL with 5 steps to check.
http://www.cisco.com/en/US/docs/unified_computing/ucs/ts/faults/reference/2.0/UCS_SEMs.html
Step 1 - Not sure how to check this - Any input on this ?
Step 2 - Have checked and even replaced the cables
Step 3 - Checked and confirmed under Equipments -> Rack-Mounts -> Fex ( 2 x N2K-C2232PP-10GE)
Step 4 - Checked and confirmed under Equipments -> Rack-Mounts -> Servers ( 4 x UCSC-C220-M3)
Step 5 - New installation no active contract as yet.
Anyone had similar issues, any assistance would be appreciated.
03-01-2013 01:42 AM
Step 1 - Have you configured Management port IP´s for FI A and B as well as Cluster IP correctly? Refer to this document for Initial System Setup:
Step 2 - Make sure the links are not cross-connected. L1 must go to L1 and L2 to L2.
03-01-2013 02:21 AM
Step 1
Management all setup with initial setup-script, confirmed in extract from running config below
scope fabric-interconnect a
set out-of-band ip 172.16.1.4 netmask 255.255.255.0 gw 172.16.1.1
scope fabric-interconnect b
set out-of-band ip 172.16.1.5 netmask 255.255.255.0 gw 172.16.1.1
scope system
set virtual-ip 172.16.1.6
Double confirmed via show commands below
CTCPFIHA-A# scope fabric-interconnect a
CTCPFIHA-A /fabric-interconnect # show detail
Fabric Interconnect:
Product Name: Cisco UCS 6248UP
PID: UCS-FI-6248UP
VID: V01
Vendor: Cisco Systems, Inc.
Serial (SN): SSI163308YF
HW Revision: 0
Total Memory (MB): 16232
OOB IP Addr: 172.16.1.4
OOB Gateway: 172.16.1.1
OOB Netmask: 255.255.255.0
Operability: Operable
Thermal Status: Ok
Current Task 1:
Current Task 2:
CTCPFIHA-A /fabric-interconnect # scope fabric-interconnect b
PID: UCS-FI-6248UP
VID: V01
Serial (SN): SSI16330FY1
HW Revision: 0
OOB IP Addr: 172.16.1.5
Thermal Status: Ok
Current Task 1:
Current Task 2:
CTCPFIHA-A /fabric-interconnect # scope system
CTCPFIHA-A /system # show detail
Systems:
Mode: Cluster
System IP Address: 172.16.1.6
System Owner:
System Site:
Description for System:
Step 2
L1<>L1 L2<>L2 confirmed and new cables tried.
03-01-2013 03:54 AM
Hello Neil,
Can you please SSH into FI and share the output of following command ?
show system firmware
show cluster extended-state
Padma
03-01-2013 04:02 AM
CTCPFIHA-A# show system firmware
UCSM:
Running-Vers: 2.1(1a)
Package-Vers: 2.1(1a)A
Activate-Status: Ready
CTCPFIHA-A# show cluster extended-state
Cluster Id: 0xb72022187f3511e2-0x9307547feeed8b24
Start time: Mon Feb 25 14:15:07 2013
Last election time: Tue Feb 26 14:40:01 2013
A: UP, PRIMARY
B: UP, SUBORDINATE
A: memb state UP, lead state PRIMARY, mgmt services state: UP
B: memb state UP, lead state SUBORDINATE, mgmt services state: UP
heartbeat state PRIMARY_OK
INTERNAL NETWORK INTERFACES:
eth1, UP
eth2, UP
HA NOT READY
No device connected to this Fabric Interconnect
03-01-2013 04:11 AM
Could it be that You haven´t connected any chassis yet? The FI´s look fine to me.
03-01-2013 04:17 AM
Hello Neil,
The output is as expected as we do not have any chassis or rack server connected to FI. SEEPROM in chassis or file in rack server management flash serves to decide active FI during spilt brain scenario.
The message would disappear once you have chassis or rack server connected to FI.
A good blog about this topic
http://ucsguru.com/2012/11/07/ha-with-ucsm-integrated-rack-mounts/
Padma
03-01-2013 04:36 AM
Hey Padma
We have 4 x UCSC-C220-M3 server connected which are discovered and displayed in the Manager Topology diagram.
Setup is as per below Document
03-01-2013 04:50 AM
Hello Neil,
Can you please share the output of following command
show server status
Are you able to connect to CIMC of the servers ? ( connect cimc
Padma
03-01-2013 05:28 AM
Hello Padma
I have left site and will be back next week wednesday day,
I will update the dicussion then.
03-01-2013 06:29 AM
CTCPFIHA-A# show service status
Service Profile Name Server Assignment Association Power State Op State
CTCPVM01 1 Assigned Associated On Ok
CTCPVM02 2 Assigned Associated On Ok
CTCPVM03 3 Assigned Associated On Ok
CTCPVM04 4 Assigned Associated On Ok
Old Unassigned Unassociated Unassociated
VM-Host-Infra Unassigned Unassociated Unassociated
03-01-2013 11:00 PM
Hello Neil,
We need more logs to investigate the issue.
Please open a TAC service request with UCSM and one rack server tech support bundle.
Padma
03-16-2013 05:33 PM
Was it just that shared storage wasn't connected or configured?
03-18-2013 12:19 AM
A Cabling Issues caused the problem.
We had the servers cabled as below.
CIMC -> FI A
LAN1 -> FI_B
Strangely, FI_B coulds see the CIMC, FI_A could not.
We recabled the servers the (as below) and re-acknowledged the servers.
LAN1 -> FI_A
LAN2 -> FI_B
Both IFs see the CIMC and HA up - all is good.
