Adaptor-FEX license requirement
Paul Marshall
I have a client who has purchased C Class Servers with VIC1225 cards and Nexus 5548UP switches but just has the base license. I'm unable to establish whether Adaptor-FEX can be used or not given the specifications suggest it bundles up everything to FCoE.
Doe's anyone have a definative answer for this?
padramas
Hello Paul,
Adapter FEX does not require license.
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9670/guide_c07-690080.html
---------- snip ----------
Verify Licensing Requirements
No A-FEX license is required for A-FEX to function.
If using FC or FCoE, make sure the appropriate license is installed.
If you are using the Layer 3 card, make sure to install the BASE license.
If you are planning to use VM-FEX, then VMFEX license is required
Table 3 - Nexus 5000
http://www.cisco.com/en/US/docs/switches/datacenter/sw/nx-os/licensing/guide/b_Cisco_NX-OS_Licensing_Guide_chapter_01.html#con_24753
Padma
padramas
Hello Paul,
Padma
Thanks, perfect. I'm having real trouble finding the required information!
