Ask the Expert: Cisco Unified Computing System (UCS) B series Upgrade & Troubleshooting Q&A
ciscomoderator
Community Manager
Community Manager
Welcome to this Cisco Support Community Ask the Expert conversation. This is a continuation of the Live Webcast event providing additional opportunity to learn and ask questions about Cisco Unified Computing System (UCS) B series Upgrade & Troubleshooting
Starting September 17th
Cisco® subject matter experts Varun Mehta and Anupam Asthana will focus on basics of Cisco UCS (Unified Computing System). With lots of companies adopting Cisco UCS, there is need to understand the UCS architecture and the complete firmware upgrade procedure which would help customers/partners to maintain and operate the UCS environment effectively.
Remember to use the rating system to let the experts know if you have received an adequate response.
Because of the volume expected during this event, they might not be able to answer every question. Remember that you can continue the conversation in Data Center under the subcommunity Unified Computing shortly after the event. This event lasts through September 24, 2014. Visit this forum often to view responses to your questions and the questions of other Cisco Support Community members.
The Webcast will help attendees to understand Cisco UCS B series upgrade procedure.
Following is the Agenda of the session :
  • Introduction to UCS Architecture.
  • UCS Upgrade Procedure.
  • Troubleshooting, Tips & Tricks related to UCS upgrade .
  • Upgrade Live Demo.
Featured Experts
Varun Mehta is a customer support engineer from the Server Virtualization team at the Cisco Technical Assistance Center in Bangalore, India. He has five years of total experience. He holds a CCIE (Routing and Switching) no 37698 and has worked on a wide range of Cisco products.
Anupam Asthana is a customer support engineer from the Server Virtualization team at the Cisco Technical Assistance Center in Bangalore, India. He has nine years of total experience. He has worked on a wide range of Cisco data center products such as Cisco UCS and Cisco Nexus 1000V.
Walter Dey
Trivial question: Customer does a firmware upgrade; after the autoinstall infrastructure he does a autoinstall server, with a maintenance policy for ack in place.
He has therefore pending activities which require a ack for every blade.
Now there is a power failure in the datacenter ? what happens ? will the blade come up with the old version and the pending activities still exist ?
achellappa3
What are some of the issues or concerns that need to be checked from a MDS/ NPV perspective for FIs' before the upgrade?
There are no special considerations related to MDS .
You may want to check the storage interop matrix:
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/mds9000/interoperability/matrix/intmatrx/Matrix8.html
