Ask the Expert: Cisco Unified Computing System (UCS) Mini Architecture, Troubleshooting
Lisa Latour
Level 6
Level 6
Cisco Unified Computing System (UCS) Mini Architecture, Troubleshooting and Upgrade Ask the Expert Continuing Discussion
(Live Webcast May 12, 2015 at 10:00 am Pacific Time / 1:00 pm Eastern Time)
Ask questions from Tuesday, May 12th, 2015 to Friday, May 22, 2015
The Cisco Unified Computing System™ is a next-generation data center platform that unites computing, networking, storage access, and virtualization resources into a cohesive system designed to reduce total cost of ownership (TCO) and increase business agility.
The system integrates a low-latency, lossless 10 Gigabit Ethernet unified network fabric with enterprise-class, x86-architecture servers. The system is an integrated, scalable, multichassis platform in which all resources participate in a unified management domain.
In the upcoming session we will cover the UCS Mini architecture, troubleshooting and upgrade procedure.
Featured Speakers
Cisco Experts
Avinash Shukla is a customer support engineer from the Server Virtualization team at the Cisco Technical Assistance Center in Bangalore, India.  He has more than 7 years of total experience. He has worked on a wide range of Cisco data center products such as Cisco UCS, Cisco Nexus 1000V, Cisco Invicta and Cisco Collaboration technology. He also holds a CCIE in Data Center & Voice
Cisco ExpertManas Kumar Nath is a customer support engineer from the Server Virtualization team at the Cisco Technical Assistance Center in Bangalore, India. He has more than 9 years of experience. He has worked on a wide range of Cisco data center products such as Cisco UCS, Cisco Nexus 1000V, Nexus 1110. He also holds VCP5 and RHCE certifications.
Sandeep Kumar is a customer support engineer from the Server Virtualization team at the Cisco Technical Assistance Center in Bangalore, India. He has over seven years of experience. He has worked on a wide range of Cisco data center products such as Cisco UCS, Cisco Nexus 1000V, ACE Load Balancers. Sandeep also holds RHCE certifications.
Find other  https://supportforums.cisco.com/expert-corner/events.
**Ratings Encourage Participation! **
Please be sure to rate the Answers to Questions
   Cisco Ask the Expert   Cisco Ask the Expert
­Can you connect the UCS emulator to physical servers?
thanks
Hi Fernando,
UCS Emulator are software only and cannot be connected to the physical servers.
Mariana Llamas
How is the traffic switched between the blades in UCS mini?
Hi Mariana,
Thanks for your question. At the moment traffic switching between blades in UCS Mini is same as in case of classic UCS.
- For traffic between blade vnics which are pinned to the same FI-IOM the switching happens at the corresponding FI-IOM.
- For traffic between vnics which are pinned to different FI-IOM it would be switched outside the FI-IOM at the upstream.
