C-Series CIMC Firmware Upgrade
GregW9393
I have a couple of C240 M4's at remote offices and need to udpate firmware on them.  I'd like to update CIMC first, then boot the HUU iso and update the rest of the firmware.  However, I can only find the HUU download, there doesn't appear to be a way to just download the CIMC firmware package by itself any more.  I also don't seem to be able to extract individual firmware packages from the HUU iso, everything is packaged together/hidden in there.
Any suggestions?
Understood. In older releases we would provide the CIMC.bin file but do not have them in the new bundle.
I would conduct a CIMC reboot before you start the HUU upgrade and you should be fine.
Wes Austin
What CIMC version are you currently running and what is your target version?
Any reason you want to update CIMC by itself and not just use HUU for everything?
Current version is really old (2.0(10b)).  I'd like to get it to the latest version.
I want to do the CIMC first because like I said, it's a remote server and I'll be using the CIMC to perform the HUU update.  So it's sort of a chicken/egg scenario.  I'd rather not have the CIMC get updated while I'm using it to run the update utility.
Thanks for the responses. Sounds like that's really the only path forward. Take care!
