CATERR_N:Sensor Failure Asserted
Simon5923
I received a minor warning on a server displaying CATERR_N:Sensor Failure Asserted.
Looking at the SEL log I can see this happening like 1-4 times a year since the server was first initialized but has now occurred multiple times in the last few days. Should I be worried?
As far as I understand, this relates to the CPU and/or the memory of the server?
ad1 | 11/20/2019 03:22:29 | CIMC | Voltage P0V75_DDR3_P1 #0x14 | Upper critical - going high | Asserted | Reading 0.72 >= Threshold 0.72 Volts
ad2 | 11/20/2019 03:22:29 | CIMC | Entity presence MAIN_POWER #0x52 | Device Absent | Asserted
ad3 | 11/20/2019 03:22:34 | CIMC | Processor CATERR_N #0x20 | Predictive Failure asserted | Asserted
ad4 | 11/20/2019 03:22:34 | CIMC | Entity presence MAIN_POWER #0x52 | Device Present | Asserted
ad5 | 11/20/2019 03:22:35 | CIMC | Entity presence BIOS_POST_CMPLT #0x53 | Device Absent | Asserted
ad6 | 11/20/2019 03:22:35 | CIMC | Platform alert LED_BLADE_STATUS #0x62 | LED color is amber | Asserted
ad7 | 11/20/2019 03:22:36 | CIMC | Processor CATERR_N #0x20 | Predictive Failure deasserted | Asserted
ad8 | 11/20/2019 03:24:27 | BIOS | System Event #0x83 | OEM System Boot Event | Asserted
ad9 | 11/20/2019 03:24:28 | CIMC | Entity presence BIOS_POST_CMPLT #0x53 | Device Present | Asserted
ada | 11/20/2019 03:24:37 | CIMC | Voltage P0V75_DDR3_P1 #0x14 | Upper critical - going high | Deasserted | Reading 0.69 <= Threshold 0.72 Volts
adb | 11/20/2019 03:24:38 | CIMC | Platform alert LED_BLADE_STATUS #0x62 | LED color is green | Asserted
adc | 11/20/2019 03:24:55 | System Mgmt Software | OS Boot #0x00 | C: boot completed | Asserted
add | 11/20/2019 03:24:55 | OEM timestamped record: Type: DC: Mfg ID: 37 01 00:Raw SEL: DD 0A DC 07 B2 D4 5D 37 01 00 00 1B C0 D4 5D 00
ade | 11/20/2019 03:36:01 | CIMC | Entity presence MAIN_POWER #0x52 | Device Absent | Asserted
adf | 11/20/2019 03:36:07 | CIMC | Processor CATERR_N #0x20 | Predictive Failure asserted | Asserted
ae0 | 11/20/2019 03:36:07 | CIMC | Entity presence MAIN_POWER #0x52 | Device Present | Asserted
ae1 | 11/20/2019 03:36:07 | CIMC | Entity presence BIOS_POST_CMPLT #0x53 | Device Absent | Asserted
ae2 | 11/20/2019 03:36:08 | CIMC | Platform alert LED_BLADE_STATUS #0x62 | LED color is amber | Asserted
ae3 | 11/20/2019 03:36:08 | CIMC | Processor CATERR_N #0x20 | Predictive Failure deasserted | Asserted
ae4 | 11/20/2019 03:36:08 | CIMC | Platform alert LED_BLADE_STATUS #0x62 | LED color is green | Asserted
ae5 | 11/20/2019 03:37:53 | BIOS | System Event #0x83 | OEM System Boot Event | Asserted
ae6 | 11/20/2019 03:37:54 | CIMC | Entity presence BIOS_POST_CMPLT #0x53 | Device Present | Asserted
ae7 | 11/20/2019 03:38:20 | System Mgmt Software | OS Boot #0x00 | C: boot completed | Asserted
ae8 | 11/20/2019 03:38:21 | OEM timestamped record: Type: DC: Mfg ID: 37 01 00:Raw SEL: E8 0A DC 2D B5 D4 5D 37 01 00 00 28 C3 D4 5D 00
ae9 | 11/21/2019 03:19:31 | CIMC | Entity presence MAIN_POWER #0x52 | Device Absent | Asserted
aea | 11/21/2019 03:19:36 | CIMC | Processor CATERR_N #0x20 | Predictive Failure asserted | Asserted
aeb | 11/21/2019 03:19:36 | CIMC | Entity presence MAIN_POWER #0x52 | Device Present | Asserted
aec | 11/21/2019 03:19:36 | CIMC | Entity presence BIOS_POST_CMPLT #0x53 | Device Absent | Asserted
aed | 11/21/2019 03:19:37 | CIMC | Platform alert LED_BLADE_STATUS #0x62 | LED color is amber | Asserted
aee | 11/21/2019 03:19:37 | CIMC | Processor CATERR_N #0x20 | Predictive Failure deasserted | Asserted
aef | 11/21/2019 03:19:38 | CIMC | Platform alert LED_BLADE_STATUS #0x62 | LED color is green | Asserted
af0 | 11/21/2019 03:21:22 | BIOS | System Event #0x83 | OEM System Boot Event | Asserted
af1 | 11/21/2019 03:21:23 | CIMC | Entity presence BIOS_POST_CMPLT #0x53 | Device Present | Asserted
af2 | 11/21/2019 03:21:49 | System Mgmt Software | OS Boot #0x00 | C: boot completed | Asserted
af3 | 11/21/2019 03:21:49 | OEM timestamped record: Type: DC: Mfg ID: 37 01 00:Raw SEL: F3 0A DC CD 02 D6 5D 37 01 00 00 CC 10 D6 5D 00
af4 | 11/21/2019 13:00:25 | CIMC | Entity presence MAIN_POWER #0x52 | Device Absent | Asserted
af5 | 11/21/2019 13:00:30 | CIMC | Processor CATERR_N #0x20 | Predictive Failure asserted | Asserted
af6 | 11/21/2019 13:00:30 | CIMC | Entity presence MAIN_POWER #0x52 | Device Present | Asserted
af7 | 11/21/2019 13:00:30 | CIMC | Entity presence BIOS_POST_CMPLT #0x53 | Device Absent | Asserted
af8 | 11/21/2019 13:00:31 | CIMC | Platform alert LED_BLADE_STATUS #0x62 | LED color is amber | Asserted
af9 | 11/21/2019 13:00:31 | CIMC | Processor CATERR_N #0x20 | Predictive Failure deasserted | Asserted
afa | 11/21/2019 13:00:31 | CIMC | Platform alert LED_BLADE_STATUS #0x62 | LED color is green | Asserted
afb | 11/21/2019 13:02:21 | BIOS | System Event #0x83 | OEM System Boot Event | Asserted
afc | 11/21/2019 13:02:21 | CIMC | Entity presence BIOS_POST_CMPLT #0x53 | Device Present | Asserted
afd | 11/21/2019 13:02:48 | System Mgmt Software | OS Boot #0x00 | C: boot completed | Asserted
afe | 11/21/2019 13:02:48 | OEM timestamped record: Type: DC: Mfg ID: 37 01 00:Raw SEL: FE 0A DC F8 8A D6 5D 37 01 00 00 F9 98 D6 5D 00
Simon
Kirk J
That alert can be generated in association with DIMM issues, so it makes sense that you appear to have a batch of DIMM alerts going on around that same time.
I would open a TAC case to get the DIMM issue corrected/evaluated, and see if the CATERR_N issue disappears.
The DIMM alert may/may not be an issue, as it seems to be hitting a marginal voltage threshhold.
Kirk...
Kirk J
Kirk...
MA Khatri
Hello Simon,
I am having the same issue with one of the Server.
Appreciate if you share that how were you able to solve this issue?
