CIMC Launch KVM Console
elarkin01
Community Member
I am on the CIMC and when I select Launch KVM Console,  I get a pop up a Do you want to continue ? I select Continue
It goes to starting application, Verifying application. ( takes about a minute )   then pops up a  Do you want to run this application ?
I check accept the risk and run this application.
It automatically goes to Connecting to KVM Server , then Message popup Login Failed or Timed out. Please try again.
I have set up a admin account under admin.
any suggestions would be greatly appreciated
Edith
I was having this issue too.
I noticed the logs reported logon failures for random users account ie 1343343, I assume this was the obfuscating the details.
I downloaded the jnlp file end editing it in notepad and there were two arguments for user and password, I updated the jnlp file with the real username and password and I was able to connect.
27 Replies 27
elarkin01
Community Member
15 views and 0 replies have I posted in the wrong section ?  Do I have enough information ?
I need to install a OS remotely and no access to the KVM
Edith Welcome to the community,
*What is the Java version you have installed in your computer? And, is it 32-64 bits?
*Can you login from another computer?
*Could you please go to Control Panel > Programs > Java > Advanced > expand Debuggin and enable loging and tracing.  Try again and share the output here.
*If you can login from another computer, then you might need to go to Control Panel > Programs > Java > Temporary Internet Files> settings > Delete files.
-Kenny
Thank you for replying Keny
here is the log file ( actual username is changed to user and IP to X's
I bolded where i see the error.
Using JRE version 1.7.0_51-b13 Java HotSpot(TM) Client VM
User home directory = C:\Documents and Settings\user
c:   clear console window
f:   finalize objects on finalization queue
g:   garbage collect
h:   display this help message
m:   print memory usage
o:   trigger logging
p:   reload proxy configuration
q:   hide console
r:   reload policy configuration
s:   dump system and deployment properties
t:   dump thread list
v:   dump thread stack
0-5: set trace level to
Missing Application-Name manifest attribute for:
https://XX.XXX.X.XXX:443/software/avctNuova.jar
Missing Permissions manifest attribute in main jar:
https://XX.XXX.X.XXX::443/software/avctNuova.jar
Java Client Version: 2.0.2.16
DebugUtil.printSystemProperties() [AIMPRESENT][true]
DebugUtil.printSystemProperties() [AVSP_VERSION][2]
DebugUtil.printSystemProperties() [HELP_URL]
[https://10.200.2.216:443/help/content/kvm_vm_help.html]
DebugUtil.printSystemProperties() [HOST][XX.XXX.X.XXX:]
DebugUtil.printSystemProperties() [KMPORT][2068]
DebugUtil.printSystemProperties() [PASSWORD][XXXXXXXXXX]
DebugUtil.printSystemProperties() [ResourceFile][com.avocent.nuova.kvm.Res]
DebugUtil.printSystemProperties() [TITLE][XX.XXX.X.XXX: - KVM Console]
DebugUtil.printSystemProperties() [USERNAME][1365180540]
DebugUtil.printSystemProperties() [USE_APCP][1]
DebugUtil.printSystemProperties() [VPORT][2068]
DebugUtil.printSystemProperties() [awt.toolkit][sun.awt.windows.WToolkit]
DebugUtil.printSystemProperties() [com.sun.security.enableCRLDP][true]
DebugUtil.printSystemProperties() [deployment.baseline.url][https://javadl-esd-
secure.oracle.com/update/baseline.version]
DebugUtil.printSystemProperties() [deployment.blacklist.url][https://javadl-esd-
secure.oracle.com/update/blacklist]
DebugUtil.printSystemProperties() [deployment.blacklisted.certs.url][https://javadl-
esd-secure.oracle.com/update/blacklisted.certs]
DebugUtil.printSystemProperties() [deployment.browser.path][C:\Program Files\Internet
Explorer\iexplore.exe]
DebugUtil.printSystemProperties() [deployment.browser.vm.iexplorer][true]
DebugUtil.printSystemProperties() [deployment.browser.vm.mozilla][true]
DebugUtil.printSystemProperties() [deployment.cache.enabled][true]
DebugUtil.printSystemProperties() [deployment.cache.jarcompression][0]
DebugUtil.printSystemProperties() [deployment.cache.max.size][-1]
DebugUtil.printSystemProperties() [deployment.capture.mime.types][false]
DebugUtil.printSystemProperties() [deployment.console.startup.mode][SHOW]
DebugUtil.printSystemProperties() [deployment.control.panel.log][false]
DebugUtil.printSystemProperties() [deployment.expiration.check.enabled][true]
DebugUtil.printSystemProperties() [deployment.insecure.jres][PROMPT]
DebugUtil.printSystemProperties() [deployment.javafx.mode.enabled][true]
DebugUtil.printSystemProperties() [deployment.javapi.cache.update][false]
DebugUtil.printSystemProperties() [deployment.javapi.lifecycle.exception][false]
DebugUtil.printSystemProperties() [deployment.javapi.log.filename][]
DebugUtil.printSystemProperties() [deployment.javapi.runtime.type][0]
DebugUtil.printSystemProperties() [deployment.javapi.stop.timeout][200]
DebugUtil.printSystemProperties() [deployment.javapi.trace.filename][]
DebugUtil.printSystemProperties() [deployment.javaws.appicon.index][C:\Documents and
Settings\aelar\Application Data\Sun\Java\Deployment\cache\6.0\appIcon\appIcon.xml]
DebugUtil.printSystemProperties() [deployment.javaws.associations][ALWAYS]
DebugUtil.printSystemProperties() [deployment.javaws.cache.update][false]
DebugUtil.printSystemProperties() [deployment.javaws.concurrentDownloads][4]
DebugUtil.printSystemProperties() [deployment.javaws.install][IF_HINT]
DebugUtil.printSystemProperties() [deployment.javaws.installURL]
[http://java.sun.com/products/autodl/j2se]
DebugUtil.printSystemProperties() [deployment.javaws.logFileName][]
DebugUtil.printSystemProperties() [deployment.javaws.muffin.max][256]
DebugUtil.printSystemProperties() [deployment.javaws.shortcut][ASK_IF_HINTED]
DebugUtil.printSystemProperties() [deployment.javaws.splash.index][C:\Documents and
Settings\aelar\Application Data\Sun\Java\Deployment\cache\6.0\splash\splash.xml]
DebugUtil.printSystemProperties() [deployment.javaws.traceFileName][]
DebugUtil.printSystemProperties() [deployment.javaws.uninstall.shortcut][false]
DebugUtil.printSystemProperties() [deployment.javaws.update.timeout][1500]
DebugUtil.printSystemProperties() [deployment.javaws.viewer.bounds][538,588,797,360]
DebugUtil.printSystemProperties() [deployment.jpi.mode.new][true]
DebugUtil.printSystemProperties() [deployment.log][true]
DebugUtil.printSystemProperties() [deployment.macosx.check.update][true]
DebugUtil.printSystemProperties() [deployment.max.output.file.size][10]
DebugUtil.printSystemProperties() [deployment.max.output.files][5]
DebugUtil.printSystemProperties() [deployment.mime.types.use.default][true]
DebugUtil.printSystemProperties() [deployment.modified.timestamp][1393418690754]
DebugUtil.printSystemProperties() [deployment.proxy.bypass.local][false]
DebugUtil.printSystemProperties() [deployment.proxy.override.hosts][]
DebugUtil.printSystemProperties() [deployment.proxy.same][false]
DebugUtil.printSystemProperties() [deployment.proxy.type][3]
DebugUtil.printSystemProperties() [deployment.security.SSLv2Hello][false]
DebugUtil.printSystemProperties() [deployment.security.SSLv3][true]
DebugUtil.printSystemProperties() [deployment.security.TLSv1][true]
DebugUtil.printSystemProperties() [deployment.security.TLSv1.1][false]
DebugUtil.printSystemProperties() [deployment.security.TLSv1.2][false]
DebugUtil.printSystemProperties() [deployment.security.askgrantdialog.notinca][true]
DebugUtil.printSystemProperties() [deployment.security.askgrantdialog.show][true]
DebugUtil.printSystemProperties() [deployment.security.authenticator][true]
DebugUtil.printSystemProperties() [deployment.security.blacklist.check][true]
DebugUtil.printSystemProperties() [deployment.security.browser.keystore.use][true]
DebugUtil.printSystemProperties() [deployment.security.clientauth.keystore.auto][true]
DebugUtil.printSystemProperties() [deployment.security.disable][false]
DebugUtil.printSystemProperties() [deployment.security.https.warning.show][false]
DebugUtil.printSystemProperties() [deployment.security.jsse.hostmismatch.warning][true]
DebugUtil.printSystemProperties() [deployment.security.level][HIGH]
DebugUtil.printSystemProperties() [deployment.security.local.applets][PROMPT]
DebugUtil.printSystemProperties() [deployment.security.mixcode][ENABLE]
DebugUtil.printSystemProperties() [deployment.security.notinca.warning][true]
DebugUtil.printSystemProperties() [deployment.security.password.cache][true]
DebugUtil.printSystemProperties() [deployment.security.permissions.manifest.required]
[true]
DebugUtil.printSystemProperties() [deployment.security.revocation.check]
[ALL_CERTIFICATES]
DebugUtil.printSystemProperties() [deployment.security.run.untrusted][PROMPT]
DebugUtil.printSystemProperties() [deployment.security.sandbox.awtwarningwindow][true]
DebugUtil.printSystemProperties() [deployment.security.sandbox.casigned][PROMPT]
DebugUtil.printSystemProperties() [deployment.security.sandbox.jnlp.enhanced][true]
DebugUtil.printSystemProperties() [deployment.security.sandbox.selfsigned][PROMPT]
DebugUtil.printSystemProperties() [deployment.security.trusted.policy][]
DebugUtil.printSystemProperties() [deployment.security.use.user.home.java.policy]
[false]
DebugUtil.printSystemProperties() [deployment.security.validation.crl][true]
DebugUtil.printSystemProperties() [deployment.security.validation.ocsp][true]
DebugUtil.printSystemProperties() [deployment.security.validation.ocsp.publisher]
[false]
DebugUtil.printSystemProperties() [deployment.system.cachedir][C:\Documents and
Settings\aelar\Application Data\Sun\Java\Deployment\SystemCache]
DebugUtil.printSystemProperties() [deployment.system.security.blacklist][C:\Program
Files\Java\jre7\lib\security\blacklist]
DebugUtil.printSystemProperties() [deployment.system.security.cacerts][C:\Program
Files\Java\jre7\lib\security\cacerts]
DebugUtil.printSystemProperties() [deployment.system.security.jssecacerts][C:\Program
Files\Java\jre7\lib\security\jssecacerts]
DebugUtil.printSystemProperties() [deployment.system.security.oldcacerts][C:\Program
DebugUtil.printSystemProperties() [deployment.system.security.oldjssecacerts][C:
\Program Files\Java\jre7\lib\security\jssecacerts]
DebugUtil.printSystemProperties() [deployment.system.security.trusted.certs][C:\Program
Files\Java\jre7\lib\security\trusted.certs]
DebugUtil.printSystemProperties() [deployment.system.security.trusted.clientauthcerts]
[C:\Program Files\Java\jre7\lib\security\trusted.clientcerts]
DebugUtil.printSystemProperties() [deployment.system.security.trusted.jssecerts][C:
\Program Files\Java\jre7\lib\security\trusted.jssecerts]
DebugUtil.printSystemProperties() [deployment.system.security.trusted.libraries][C:
\Program Files\Java\jre7\lib\security\trusted.libraries]
DebugUtil.printSystemProperties() [deployment.system.tray.icon][false]
DebugUtil.printSystemProperties() [deployment.trace][true]
DebugUtil.printSystemProperties() [deployment.update.mime.types][true]
DebugUtil.printSystemProperties() [deployment.user.cachedir][C:\Documents and Settings
\aelar\Application Data\Sun\Java\Deployment\cache]
DebugUtil.printSystemProperties() [deployment.user.extdir][C:\Documents and Settings
\aelar\Application Data\Sun\Java\Deployment\ext]
DebugUtil.printSystemProperties() [deployment.user.logdir][C:\Documents and Settings
\aelar\Application Data\Sun\Java\Deployment\log]
DebugUtil.printSystemProperties() [deployment.user.security.blacklist][C:\Documents and
Settings\aelar\Application Data\Sun\Java\Deployment\security\blacklist]
DebugUtil.printSystemProperties() [deployment.user.security.blacklist.dynamic][C:
\Documents and Settings\aelar\Application Data\Sun\Java\Deployment\security
\blacklist.dynamic]
DebugUtil.printSystemProperties() [deployment.user.security.blacklisted.certs][C:
\blacklisted.certs]
DebugUtil.printSystemProperties() [deployment.user.security.exception.sites][C:
\exception.sites]
DebugUtil.printSystemProperties() [deployment.user.security.policy][file:/C:/Documents
%20and%20Settings/aelar/Application%20Data/Sun/Java/Deployment/security/java.policy]
DebugUtil.printSystemProperties() [deployment.user.security.sandbox.certs][C:\Documents
and Settings\aelar\Application Data\Sun\Java\Deployment\security\sandbox.certs]
DebugUtil.printSystemProperties() [deployment.user.security.saved.credentials][C:
\Documents and Settings\aelar\Application Data\Sun\Java\Deployment\security\auth.dat]
DebugUtil.printSystemProperties() [deployment.user.security.trusted.cacerts][C:
\trusted.cacerts]
DebugUtil.printSystemProperties() [deployment.user.security.trusted.certs][C:\Documents
and Settings\aelar\Application Data\Sun\Java\Deployment\security\trusted.certs]
DebugUtil.printSystemProperties() [deployment.user.security.trusted.clientauthcerts]
[C:\Documents and Settings\aelar\Application Data\Sun\Java\Deployment\security
DebugUtil.printSystemProperties() [deployment.user.security.trusted.jssecacerts][C:
\trusted.jssecacerts]
DebugUtil.printSystemProperties() [deployment.user.security.trusted.jssecerts][C:
\trusted.jssecerts]
DebugUtil.printSystemProperties() [deployment.user.security.trusted.libraries][C:
\trusted.libraries]
DebugUtil.printSystemProperties() [deployment.user.tmp][C:\Documents and Settings
\aelar\Application Data\Sun\Java\Deployment\tmp]
DebugUtil.printSystemProperties() [deployment.version][7.21]
DebugUtil.printSystemProperties() [deployment.webjava.enabled][true]
DebugUtil.printSystemProperties() [file.encoding][Cp1252]
DebugUtil.printSystemProperties() [file.encoding.pkg][sun.io]
DebugUtil.printSystemProperties() [file.separator][\]
DebugUtil.printSystemProperties() [http.auth.serializeRequests][true]
DebugUtil.printSystemProperties() [https.protocols][TLSv1,SSLv3]
DebugUtil.printSystemProperties() [java.awt.graphicsenv]
[sun.awt.Win32GraphicsEnvironment]
DebugUtil.printSystemProperties() [java.awt.printerjob][sun.awt.windows.WPrinterJob]
DebugUtil.printSystemProperties() [java.class.path][C:\Program Files\Java\jre7\lib
\deploy.jar]
DebugUtil.printSystemProperties() [java.class.version][51.0]
DebugUtil.printSystemProperties() [java.endorsed.dirs][C:\Program Files\Java\jre7\lib
\endorsed]
DebugUtil.printSystemProperties() [java.ext.dirs][C:\Program Files\Java\jre7\lib
\ext;C:\WINDOWS\Sun\Java\lib\ext]
DebugUtil.printSystemProperties() [java.home][C:\Program Files\Java\jre7]
DebugUtil.printSystemProperties() [java.io.tmpdir][C:\DOCUME~1\aelar\LOCALS~1\Temp\1\]
DebugUtil.printSystemProperties() [java.library.path][C:\Program Files\Java
\jre7\bin;C:\WINDOWS\Sun\Java\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\Program Files\Java
\jre7\bin;C:\Program Files\Internet Explorer;;C:\WINDOWS\system32;C:\WINDOWS;C:
\WINDOWS\System32\Wbem;C:\PROGRA~1\BMCSOF~1\Patrol3\bin;"C:\Program Files\Java
\jre7\bin";.]
DebugUtil.printSystemProperties() [java.protocol.handler.pkgs]
[com.sun.javaws.net.protocol|com.sun.deploy.net.protocol|com.sun.deploy.net.protocol]
DebugUtil.printSystemProperties() [java.quick.starter][true]
DebugUtil.printSystemProperties() [java.rmi.server.RMIClassLoaderSpi]
[com.sun.jnlp.JNLPRMIClassLoaderSpi]
DebugUtil.printSystemProperties() [java.runtime.name][Java(TM) SE Runtime Environment]
DebugUtil.printSystemProperties() [java.runtime.version][1.7.0_51-b13]
DebugUtil.printSystemProperties() [java.security.policy][file:C:\Program Files\Java
\jre7\lib\security\javaws.policy]
DebugUtil.printSystemProperties() [java.specification.name][Java Platform API
Specification]
DebugUtil.printSystemProperties() [java.specification.vendor][Oracle Corporation]
DebugUtil.printSystemProperties() [java.specification.version][1.7]
DebugUtil.printSystemProperties() [java.vendor][Oracle Corporation]
DebugUtil.printSystemProperties() [java.vendor.url][http://java.oracle.com/]
DebugUtil.printSystemProperties() [java.vendor.url.bug]
[http://bugreport.sun.com/bugreport/]
DebugUtil.printSystemProperties() [java.version][1.7.0_51]
DebugUtil.printSystemProperties() [java.vm.info][mixed mode, sharing]
DebugUtil.printSystemProperties() [java.vm.name][Java HotSpot(TM) Client VM]
DebugUtil.printSystemProperties() [java.vm.specification.name][Java Virtual Machine
Specification]
DebugUtil.printSystemProperties() [java.vm.specification.vendor][Oracle Corporation]
DebugUtil.printSystemProperties() [java.vm.specification.version][1.7]
DebugUtil.printSystemProperties() [java.vm.vendor][Oracle Corporation]
DebugUtil.printSystemProperties() [java.vm.version][24.51-b03]
DebugUtil.printSystemProperties() [javaplugin.proxy.config.type][direct]
DebugUtil.printSystemProperties() [javawebstart.version][javaws-10.51.2.13]
DebugUtil.printSystemProperties() [jnlpx.heapsize][256M,512M]
DebugUtil.printSystemProperties() [jnlpx.home][C:\Program Files\Java\jre7\bin]
DebugUtil.printSystemProperties() [jnlpx.jvm][C:\Program Files\Java\jre7\bin\javaw.exe]
DebugUtil.printSystemProperties() [jnlpx.origFilenameArg][C:\Documents and Settings
\aelar\Local Settings\Temporary Internet Files\Content.IE5\ABQ165MX\viewer.jnlp
(10.200.2[1].jnlp]
DebugUtil.printSystemProperties() [jnlpx.remove][false]
DebugUtil.printSystemProperties() [jnlpx.splashport][4028]
DebugUtil.printSystemProperties() [line.separator][
DebugUtil.printSystemProperties() [os.arch][x86]
DebugUtil.printSystemProperties() [os.name][Windows 2003]
DebugUtil.printSystemProperties() [os.version][5.2]
DebugUtil.printSystemProperties() [path.separator][;]
DebugUtil.printSystemProperties() [sun.arch.data.model][32]
DebugUtil.printSystemProperties() [sun.awt.enableExtraMouseButtons][true]
DebugUtil.printSystemProperties() [sun.awt.warmup][true]
DebugUtil.printSystemProperties() [sun.boot.class.path][C:\Program Files\Java\jre7\lib
\resources.jar;C:\Program Files\Java\jre7\lib\rt.jar;C:\Program Files\Java\jre7\lib
\sunrsasign.jar;C:\Program Files\Java\jre7\lib\jsse.jar;C:\Program Files\Java\jre7\lib
\jce.jar;C:\Program Files\Java\jre7\lib\charsets.jar;C:\Program Files\Java\jre7\lib
\jfr.jar;C:\Program Files\Java\jre7\classes;C:\Program Files\Java\jre7\lib
\javaws.jar;C:\Program Files\Java\jre7\lib\deploy.jar;C:\Program Files\Java\jre7\lib
\plugin.jar]
DebugUtil.printSystemProperties() [sun.boot.library.path][C:\Program Files\Java
\jre7\bin]
DebugUtil.printSystemProperties() [sun.cpu.endian][little]
DebugUtil.printSystemProperties() [sun.cpu.isalist][pentium_pro+mmx pentium_pro
pentium+mmx pentium i486 i386 i86]
DebugUtil.printSystemProperties() [sun.desktop][windows]
DebugUtil.printSystemProperties() [sun.io.unicode.encoding][UnicodeLittle]
DebugUtil.printSystemProperties() [sun.java.command][com.sun.javaws.Main C:
\DOCUME~1\aelar\LOCALS~1\Temp\1\javaws2]
DebugUtil.printSystemProperties() [sun.java.launcher][SUN_STANDARD]
DebugUtil.printSystemProperties() [sun.jnu.encoding][Cp1252]
DebugUtil.printSystemProperties() [sun.management.compiler][HotSpot Client Compiler]
DebugUtil.printSystemProperties() [sun.os.patch.level][Service Pack 2]
DebugUtil.printSystemProperties() [trustProxy][true]
DebugUtil.printSystemProperties() [user.country][US]
DebugUtil.printSystemProperties() [user.dir][C:\Documents and Settings\user\Desktop]
DebugUtil.printSystemProperties() [user.home][C:\Documents and Settings\user]
DebugUtil.printSystemProperties() [user.language][en]
DebugUtil.printSystemProperties() [user.name][user]
DebugUtil.printSystemProperties() [user.script][]
DebugUtil.printSystemProperties() [user.timezone][America/Halifax]
DebugUtil.printSystemProperties() [user.variant][]
DebugUtil.printSystemProperties() [vmprivilege][true]
MacroHotkeyManager.initCustom() Current Directory [C:\Documents and Settings\aelar
\Desktop]
MacroHotkeyManager.initCustom() Loading soft keys ...
MacroHotkeyManager.initCustom() LOCAL  []
MacroHotkeyManager.initCustom() STATIC []
MacroKeyStrokeMap.init() [macros_en.properties]
MacroHotkeyManager.addMacroStatic()
standalone client, continue executing pack()
MainWindow.pack()
MainWindow.pack() Max Size  [1680 x 1020]
MainWindow.pack() Preferred [8 x 27]
MainWindow.pack() Frame     [600 x 400]
MainWindow.pack() Scroll    [104 x 0]
MainWindow.pack() View      [104 x 0]
MainWindow.pack()
MainWindow.pack()
MainWindow.pack() Preferred [1032 x 818]
MainWindow.pack() Frame     [1032 x 818]
MainWindow.pack() Scroll    [1024 x 768]
MainWindow.pack() View      [1024 x 768]
MainWindow.pack()
MainWindow.pack()
MainWindow.pack()
getting Primary socket
in receiveSessionSetup
MainWindow.pack()
MainWindow.pack() Preferred [828 x 670]
MainWindow.pack() Frame     [828 x 670]
MainWindow.pack() Scroll    [820 x 620]
MainWindow.pack() View      [820 x 620]
MainWindow.pack()
MainWindow.pack()
MainWindow.pack()
ProtocolAPCP: Version [2.37]
ProtocolAPCP: CONNECTION_TYPE_SSL_ANONYMOUS
OS: Windows 2003
KVM SSL session is using protocol TLSv1 with cipher TLS_RSA_WITH_AES_128_CBC_SHA
NativeKeyboard.init() Native library loading [jawt]
JNLPClassLoader: Finding library jawt.dll
NativeKeyboard.init() Native library loading [avctKVMIO]
JNLPClassLoader: Finding library avctKVMIO.dll
NativeKeyboard.init() Native library loading complete.
KVMIOWindowListener::setup
NativeKeyboard.setPassthroughEnabled() [true]
NativeKeyboard.setPassthroughEnabled() [false]
NuovaViewerMainController.propertyChange() [PASSTHROUGH_AVAILABLE]
02/26/2014 08:46:42:237: User login response: 3 [Channel access is denied.]
login failed : status code = 3
java.net.SocketException: Software caused connection abort: socket write error
    at java.net.SocketOutputStream.socketWrite0(Native Method)
    at java.net.SocketOutputStream.socketWrite(Unknown Source)
    at java.net.SocketOutputStream.write(Unknown Source)
    at sun.security.ssl.OutputRecord.writeBuffer(Unknown Source)
    at sun.security.ssl.OutputRecord.write(Unknown Source)
    at sun.security.ssl.SSLSocketImpl.writeRecordInternal(Unknown Source)
    at sun.security.ssl.SSLSocketImpl.writeRecord(Unknown Source)
    at sun.security.ssl.AppOutputStream.write(Unknown Source)
    at java.io.BufferedOutputStream.flushBuffer(Unknown Source)
    at java.io.BufferedOutputStream.flush(Unknown Source)
    at java.io.DataOutputStream.flush(Unknown Source)
    at com.avocent.kvm.base.protocol.PacketManager.writeRequest(Unknown Source)
    at com.avocent.kvm.base.protocol.PacketManager$SendThread.run(Unknown Source)
javax.net.ssl.SSLException: Connection has been shutdown: javax.net.ssl.SSLException:
    at sun.security.ssl.SSLSocketImpl.checkEOF(Unknown Source)
    at sun.security.ssl.SSLSocketImpl.checkWrite(Unknown Source)
Caused by: javax.net.ssl.SSLException: java.net.SocketException: Software caused
    at sun.security.ssl.Alerts.getSSLException(Unknown Source)
    at sun.security.ssl.SSLSocketImpl.fatal(Unknown Source)
    at sun.security.ssl.SSLSocketImpl.handleException(Unknown Source)
    ... 6 more
Caused by: java.net.SocketException: Software caused connection abort: socket write
error
    ... 6 more
    ... 6 more
error
    ... 6 more
    ... 6 more
error
    ... 6 more
    ... 6 more
error
    ... 6 more
    ... 6 more
error
    ... 6 more
    ... 6 more
error
    ... 6 more
    ... 6 more
error
    ... 6 more
Edith,
Thanks for the output, what about my other questions
-Kenny
Hi Kenny
Java version is :
Can only attempt from this one server firewall rules have been open to allow KVM access only from this one server.
I checked the server on location and it appears the OS is stuck on looking for Raid drivers !
would this affect the KVM ?
is there a alternate  remote way to view and  install the Redhat OS ?
Edith,
No other way to do it remotely unless you have your own tool for that.
Could you please check if there is any other Java versions installed in the computer?
Have you tried to go to Control Panel > Programs > Java > Temporary Internet Files> settings > Delete files. As I suggested before?  Also, you may try to go to Java Security and lower the Security Level?  See below:
-Kenny
After upgrade Java 8 don't worked CIMC KVM. The error reported was "Errror: javax.net.ssl.SSLHandshakeException: Received fatal alert: handshake_failure".
The error persisted in two computers, one Windows 7 and other Windows 8.1.
For Java 8 the low security level is High only, there is no chance for Low level.
I have downgraded to Java 7 and all fine.
There will solution for Java 8 and higher?
Maybe this may help
Check your UCSM certificate - is it valid:
SomeSystem#  scope security
SomeSystem/security #  show keyring detail
Keyring default:
    RSA key modulus: Mod1024
    Trustpoint CA:
    Cert Status: Expired
    Certificate:
    Data:
        Validity
            Not Before: Jun 15 04:58:51 2012 GMT
            Not After : Jul 15 04:58:51 2012 GMT
If that is the case then you may re-generate the keyring.
Thanks for this option but don't fine for my.
The certificate validity report is until DEC 29 2023 and the UCS firmware versión is 1.5 (3).
JAVA 8 wont support for cimc,Java 6 and 7 will support,jave7 perfectly work only in windows 8 not in windows 7...
Go through the below link for more idea
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/release/notes/ucs_2_2_rn.html
Faced the same issue recently, verified the network connectivity and firewall ports.Then disabled the Java version 8, deleted the temp files under control panel--java--General tab and cleared history on browser and tried launching the KVM with 7. I am able to launch now.
Any Update for Java 8 update 20 and higher?
I just installed Java 8 Update 45 with the same negative result.
I returned to downgrade Java 7 Update 75 and fine.
