CIMC - Modifying Threshold Values in CIMC
Harish Chopra
I want to modify the threshold values for temperature, voltage etc given in the CIMC of a C240 Series UCS box.
In the CIMC window it shows me what is the current value and max/min threshold values but it doesn't give me option to change the threshold values. It's grey out. I logged in as admin with admin role assigned.
Can anyone please guide me how we can change this using cli or gui, any method.
C240-XXXXXX# show version
Firmware Version
2.0(9e)
Harish
Kirk J
Those are not modifiable.
These are preset to specs based requirements.
Some of those will vary such as Processor UNC/UC temps, depending on exact Processors present.
The  Product managers did mention you can use the UCSM emulator to see what kind of alerts occur, and can modify some of the simulated sensor values there.
Kirk...
