CIMC syncrhonize with Active Directory
walter_beach
I'm trying to use Active Directory Authentication to connect to CIMC and it is not working.
Following documentation I have done the following:
Logged on to the website
Went to Admin and then to Active Directory
Enabled: Checked
Server IP Address: static IP of domain controller
Timeout: 60
Enable Encryption: unchecked
Domain: domain name.  Example: test.local
Attributes: CiscoAVPair
In AD Schema
I added the attribute:
CiscoAVPair
Description: CiscoAVPair
Common Name: CiscoAVPair
X 500 OID: 1.3.6.1.4.1.9.287247.1
Syntax: Case Sensitive String
Minimum: Blank
Maximum: Blank
Attribute is active: Checked
Index this attribute: unchecked
replicate this attribute to the global catalog: unchecked
Attribute is copied when duplicating a user: unchecked
index this attribute for containerized searches: unchecked
I added the pair under classes for user
Under my account in adsi edit I went into my properties found the CiscoAVPair
and changed its properties to
shell:roles="admin"
I tried logging on as
user
password
and
test\user
password
Both say Login failed.  Verify that your username and password are correct.
Thank you,
Walter
7 Replies 7
padramas
Walter,
What is the CIMC version ?
Padma
Thank you for your reply.
Cisco Integrated Management Controller
ucs-c2xx-m2
Version 1.3(2j)
Hello Walter,
I tested with 1.4 and had no issues with it.
Can you please check CLI access ?
If it is Linux client,
ssh -l \\
If it fails, please login into CIMC with local user account and provide us the relevant log messages from CIMC > Admin > CIMC log section for the failed login attempt.
Padma
I found the following entries in the log that seem related.
I tried from Putty and it did not work.   I tried vdc\bea0196 and just bea0196 and neither seemed to matter
pam_session_manager(sshd:auth): Authentication Failure user bea0196
authTempCredentials2() - could not open /tmp/aim/dynamic/tempcred/bea0196
last message repeated 15 times
mcddI2CDrv.c:861:PI2CPerformOP: ioctl to driver failed to read Bus[f0].Dev[c2]!  ErrorStatus[fe]
Login failed (user:bea0196, ip:10.86.253.13, service:sshd)
pam_auth_status(sshd:auth): Login Failed for user=bea0196, host=10.86.253.13
pam_local_manager(sshd:auth): Authentication Failure user bea0196
pam_ldap_manager(sshd:auth): Start ----------->
Thank you,
Walter
Can you please share additional logs for the event ?
LDAP messages would be logged by pam_ldap_manager
Padma
Here are the results
pam_ldap_manager(webgui:account): Could not get pam data for authTok
pam_ldap_manager(webgui:account): At least one Role Group must be configured
Hello Walter,
Please open a TAC service request along with the logs so that we can take a look at it.
Padma
