Cisco UCS 5108 Chassis with FI6324 - CIMC SSL CSR
Keef
Good afternoon!
I am working to secure my 5108 blade chassis CIMC access with CA signed SSL certificates but I'm hitting a snag. The CSRs generated by the UCSM GUI use the legacy SHA1 hashing algorithm and I can't see any way to change to SHA256/512.
It looks like the "Key Rings" in the UCSM GUI only allow for key-length customization but do not allow for hashing algorithm customization.
Is it possible to generate CSRs with SHA256 on the UCSM?
Thanks!
Kirk J
Greetings
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuz64587/?reffering_site=dumpcr
I just checked a test CSR on 3.23c, and it had a sha256 hashing algorithm.
Looks like 3.2(3a) or higher changed the default to sha256.
Kirk...
Kirk J
Greetings
Kirk...
Thanks, Kirk!
I upgraded to 3.23c and the CSRs are now generated with a SHA256 hash.
Interesting that this is not configurable but I'm all set now!
