cisco ucs adaptor issues with vmware operations manager
HI All,
Need help getting authentication to work properly with Cisco developed plugin for vmware operations manager.  Vmware seems to think problem lies with the cisco adapter.    Copy of the error from vmware support:
2016-05-23 09:08:02,569 ERROR [Task Processor worker thread 6]  com.integrien.alive.common.communication.CommunicatorWorkItem.run - Unable to process task Test connection id:11080 from collector:1
java.lang.NoSuchMethodError: com.google.common.io.Closeables.closeQuietly(Ljava/io/Closeable;)V
        at com.vmware.ops.api.client.internal.DefaultClient.tryReadingRawBody(DefaultClient.java:292)
        at com.vmware.ops.api.client.internal.DefaultClient.handleError(DefaultClient.java:274)
        at org.springframework.web.client.RestTemplate.handleResponseError(RestTemplate.java:557)
        at org.springframework.web.client.RestTemplate.doExecute(RestTemplate.java:515)
        at org.springframework.web.client.RestTemplate.execute(RestTemplate.java:486)
        at org.springframework.web.client.RestTemplate.getForEntity(RestTemplate.java:277)
        at com.vmware.ops.api.client.internal.RestClientProxy.invoke(RestClientProxy.java:149)
        at com.vmware.ops.api.client.internal.DefaultClient$InvocationHandlerWrapper.invoke(DefaultClient.java:228)
        at com.sun.proxy.$Proxy188.getUsers(Unknown Source)
        at com.vmware.ops.api.client.internal.handlers.UsersHandler.handle(UsersHandler.java:20)
        at com.vmware.ops.api.client.internal.DefaultClient$InvocationHandlerWrapper.invoke(DefaultClient.java:226)
        at com.cisco.ucs.vcops.UcsmAdapter.onTest(UcsmAdapter.java:600)
        at com.integrien.alive.common.adapter3.AdapterBase.test(AdapterBase.java:1148)
        at com.integrien.alive.collector.Collector.testConnection(Collector.java:924)
        at com.integrien.alive.collector.CollectorTaskHandler.handleTestConnection(CollectorTaskHandler.java:205)
        at com.integrien.alive.common.communication.task.TaskTest.processTask(TaskTest.java:35)
        at com.integrien.alive.common.communication.CommunicatorWorkItem.run(CommunicatorWorkItem.java:36)
        at com.integrien.alive.common.util.ThreadPool$WorkerItem.run(ThreadPool.java:253)
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
        at java.lang.Thread.run(Thread.java:745)
Any Clue ?
Saleem
Experiencing exact same behavior (down to java stack error). VRO 6.3, UCSM 2.2(6e) UCS Adapter 2.0.2.
