Cisco UCS FI 6120 and EMC VNX 5500 Direct Connectivity
ahmed.abdallah
Hi all,
I have 2 Cisco FI 6120, with 6 port 8GB FC expantion module. I also have 2 EMC VNX 5500 storage, my question is:can I connect the ports on the FI's expantion module directly to VNX 5500 storage (there is 2 * 4 ports 8GB FC modules connected to each storage) without the need of a FC switch?.
Hope to hear from you soon.
richbarb
Yes, you can connect a storage port directly in the fabric interconnect.
First of all, you must change the Fabric Interconnect SAN scope to "switch mode". (It requires a reboot).
After that, you can configure storage ports and perform zoning.
There is a guide that can help you:
http://www.cisco.com/en/US/products/ps11350/products_configuration_example09186a0080c0a508.shtml
Please rate all useful answers.
Regards.
Richard
Dear Richard,
Many thanks for your reply and for the useful information you provided.
