Bookmark
Subscribe
939
Cisco UCS Management interface - Integrated Management Controller (CIMC)
Geotho2481
When giving CIMC IP address, I keep receiving error setting IP address. Please change Nic mode but I’ve tried both mic modes and these are the exact same settings on the other CIMC I am using and it worked.
Kirk J
Greetings.
If you haven't already, do a hard power reset (power plug pull for 30 seconds).
If that doesn't work, trigger the CIMC factory defaults.
If that doesn't work, try downloading and applying a newer HUU firmware ISO and write that to USB.
I believe the newer version of the Rufus USB boot maker will work with post 2.0 HUU.
Kirk..
I’ve tried everything but the firmware because the other UCS I am working with is on the same version and is working fine.
