Cisco UCSM Emulator
Hello Community,
I'm practising with the Cisco UCS Manager Emulator, however I'm having a problem resolving the servers, see image. Can someone let me know where I'm going wrong?
Carlton
cpatte7372
Keny Perez
Level 8
Level 8
I dont use the emulator that much but for what I understand, you need to select your hardware.. did you select the blade you want to use?
That "Needs resolution" usually shows up in the real UCSM when you decomission a blade and you have not removed it.
-Kenny
Grace Zhu
Right click on the blade picture, click on resolve slot issue, there will be a link, click on the link to accept the blade, then you can re-ack the blade
Grace Zhu
Also, you will not be able to re-ack the blade until identifying step is complete.  You can watch the progress in FSM.  When it reach 100%, the re-ack link will be available for you.
