08-04-2015 07:43 PM - edited 03-01-2019 12:18 PM
I'm seeing a lot of these errors in the UCS Manager Event Logs. I tried to search for E4196386, but can't seem to find a reference to it.
Anyone know if these are normal events or should I be worried? The Netapp guys are seeing a lot of flogi's.
Code E4196386 Adapter 11/8/1 restarted. The Chassis and Blade number changes in all the entries, so not just one combination having issues, seems like it goes through and restarts all of them.
Firmware 2.2(3c)
Ernie
08-11-2015 05:39 AM
So this is a a good question with very generic information, so let me ask you some other questions so we can start to answer to you.
-What blade(s) model?
-What is the adapter(s) model?
-What OS and what (storage) driver version is it running?
-Is this FC, FCoE, a direct attached NetApp?
This will help us get started.
-Kenny
08-24-2015 12:32 PM
I'm seeing the same thing as well...
Code: 2.2 (3g)
Blade Model
Adapter Model
OS and Storage driver version
FC with an EMC VNX 5300
Jeff
08-25-2015 01:26 PM
*Can you get me the enic driver?
*Can you go to the inventory tab> CPU and tell me if the CPU shows as version 2 (v2)?
*Please paste the output of the commad "vmware -vl"
*Get the following commands from the server:
#show service-profile circuit server x/y <<<<x=chassis y=server
(nxos)# show log log | last 40
(nxos)# show log nvram | last 40
-Kenny
08-25-2015 02:00 PM
Here is the requested information
enic driver
CPU shows as version 2?
Output of "vmware -vl"
Output of show service-profile command
DEV-801-UCS-A# show service-profile circuit server 2/2
Service Profile: DEV_vCloud/desx0836
Server: 2/2
Fabric ID: A
Path ID: 1
VIF vNIC Link State Oper State Prot State Prot Role Admin Pin Oper Pin Transport
889 vmnic0-mgt-a Up Active No Protection Unprotected 0/0 0/6 Ether
890 vmnic1-vmo-a Up Active No Protection Unprotected 0/0 0/6 Ether
891 vmnic2-ft-a Up Active No Protection Unprotected 0/0 0/6 Ether
892 vmnic3-vm-a Up Active No Protection Unprotected 0/0 0/6 Ether
897 vmhba1-a Up Active No Protection Unprotected 0/0 0/20 Fc
9089 Up Active No Protection Unprotected 0/0 0/0 Ether
Fabric ID: B
Path ID: 1
893 vmnic4-mgt-b Up Active No Protection Unprotected 0/0 0/7 Ether
894 vmnic5-vmo-b Up Active No Protection Unprotected 0/0 0/7 Ether
895 vmnic6-ft-b Up Active No Protection Unprotected 0/0 0/7 Ether
896 vmnic7-vm-b Up Active No Protection Unprotected 0/0 0/7 Ether
898 vmhba2-b Up Active No Protection Unprotected 0/0 0/40 Fc
9090 Up Active No Protection Unprotected 0/0 0/0 Ether
Output of log and nvram logs
08-25-2015 02:20 PM
I had more today at 12:57. I ran the show logs, but neither the log nor nvram shows anything going on at that time.
eNIC - 2.1.2.59
CPU E5-2697-v2
Blades are running RHEL
Ernie
08-26-2015 08:13 AM
jselover16...
Server 2/2 is running the proper drivers. And I see a lot of "VIF DOWN" for server 2/2 on Aug 22nd...
Can you please paste the out of the following commands:
#connect local a
#con iom 2
#show platform software woodside oper
#exit
#exit
#connect local b
#con iom 2
Thanks in advanced,
-Kenny
08-26-2015 08:45 AM
08-26-2015 09:02 AM
thanks, one more output...
#connect local a
#con iom 2
#show platform software woodside sts
-Kenny
08-26-2015 09:10 AM
08-26-2015 09:27 AM
So you have 2 blades and 2 cables between IOM and FI... why do we have port 3 connected instead of port 2 (I am talking about the IOM)? With 2 links between FI&IOM your server 2 should be pinned to port2 but is not connected so I do not know how this may behave in that condition (not saying that is the issue, just saying how it is documented)
I see HIFs (backplane ports in the IOM) 25 & 27 have flapped 8 times and the last one was on Aug 22nd and that is the reason why we see the VIFs going down on the 22nd.
Please open a TAC case base on this post and add the logs you provided here or just use this link as reference and have TAC get deep into what is going.. If you dont mind, please give feedback here when you get to the root cause. The information you have now is a very good start to get into what is going on... may be a known bug I am not aware of yet 🙂
Please rate all helpful answers
-Kenny
08-26-2015 09:30 AM
I actually already opened up a TAC case, i just commented on this thread as it was the same issue and i was waiting on my account to be added to the support contract. I have already referenced this post in the ticket. I will update it with the results when I have them.
08-26-2015 09:39 AM
I also opened a case and was told to upgrade the firmware and then see if we are still seeing the issue.
Ernie
08-26-2015 09:49 AM
eefranzen,
If you run the same commands I have requested in this thread, do you also see the backplane ports of the IOM flapping for the specific server where the adapter is showing the "Code E4196386 Adapter ##/#/# restarted" message?
-Kenny
