configure port channel between IO Module and FI
amoussaPersonal
I have the current setup
UCS chassis (4 uplinks) --> FI --> (Port channel) --> N5K --> (port channel) --> VSS 6500
I configure port channel between IO Module and the FI by changing to policy to "Port Channel" and set the link to 4
FI has created a portchannel under "Internal" containing all the FI interfaces that are connected to the IO module.
I have installed ESXI on a blade but i was unable to reach it, even the esx was unable to ping the gateway.
VLAN tagging is enabled from the ESX server.
I have issued the command "show mac address-table | inc <mac address of the vnic assigned from thre service profile> on both the N5K and thr 6500 and the mac is there.
I have allowed all the vlans on the vNIC from the service profile.
am I missing anything?
thanks
padramas
Can you please check whether your ESXi vmkernel interface ip address learned on right VLAN on FI / upstream switch or not.
connect nxos
show mac-address-table | inc
Padma
