Different Fabric Interconnect Models Same chassis
Youssef Aoufi
Level 5
Level 5
Hi Team,
Can i mix different Fabric Interconnect Models with the same UCS Chassis. For Example : 1x6248 and 1x6332 instead of 2x6248 or 2x6332?
RedNectar
Hi  Youssef,
Fabric Interconencts of different models is only supported during an upgrade process from say 2x6248 to 2x6332
I hope this helps
Don't forget to mark answers as correct if it solves your problem. This helps others find the correct answer if they search for the same problem
RedNectar aka Chris Welsh.
RedNectar
Hi  Youssef,
I hope this helps
Thank you Chris,
Really appreciate!
