EMC Data Domain directly connected as a VTL
dani_bosch
Can I connect an EMC Data Domain working as a VTL (with EMC Networker) directly to Fabric Interconnects of a UCS 2.1?
Thanks a lot,
Direct attach topology is not tested and hence not supported.
It might work though.
Padma
padramas
Hello Dani,
Direct attachment of Tape library system to FI is not supported.
http://www.cisco.com/en/US/products/ps10477/prod_technical_reference_list.html
Padma
Is not supported, but it should work.....or it wouldn't even technically work?
Padma
