How to call the eventSubscribe method of Cisco IMC on UCS C?
xinwen
I meet the issue to subscribe to Cisco IMC for event on UCS C.
And I did it with below steps by referring to "Cisco UCS Rack-Mount Servers Cisco IMC XML API Programmer Guide 2.0".
Get the token
Send the http request with below data.
<eventSubscribe
cookie="<real_cookie>">
</eventSubscribe>
3. The Cisco IMC return below error after timeout.
<eventSubscribe cookie="1440595732/81b92a7c-1e37-1e37-849e-0ebc24ea72f8" response="yes" errorCode="552" invocationResult="invalid-cookie" errorDescr="Authorization required"> </eventSubscribe>
How can I get this worked?
Appreciated for any response.
Vincent
Jeffrey Foster
Hi Vincent,
You need to use aaaKeepAlive to keep this connection alive, otherwise the connection will be closed automatically by CIMC.  It sounds like this might be the issue you are running into.
Please note the following passage from the XML API Programmers Guide:
“An event channel connection opened by a user will be closed automatically by Cisco IMC after 600 seconds of inactivity associated with the event channel session cookie. To prevent automatic closing of the event channel connection by Cisco IMC, the user must either send the aaaKeepAlive request for the same event channel session cookie within 600 seconds or send any other XML API method to Cisco IMC using the same event channel session cookie.”
https://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/c/sw/api/2-0/b_Cisco_IMC_api_2_0.pdf
Jeff
