07-01-2021 04:20 AM
Hi Expert ,
i have a situation , our hyperflex cluster is good , up and running ,, but we deleted the HX installer vm accidently, we need to add some vlan's now...
pls help it's urgent.
Solved! Go to Solution.
07-01-2021 04:57 AM - edited 07-01-2021 05:05 AM
As root, log into your HX connect IP via SSH, and run : hx_post_install
You should get same options as your installer provided.
It's actually only a couple of steps to manually add vlans:
Kirk
Kirk
