IP source routing must be disabled
MOHAN.RAJ1
Hi Team
I needs to disable the IP source routing must be disable on ucsmanager. can you please anyone tell me where i can disable it.
If we disable may i know what impact we will get.
Thanks in Advance
Mohan
Mohan,
But there is no data plane routing on FIs, NXOS. Let me demonstrate.
bdsol-6296-01-B(nxos)# show ip route
IP Route Table for VRF "default
'*' denotes best ucast next-hop
'**' denotes best mcast next-hop
'[x/y]' denotes [preference/metric]
bdsol-6296-01-B(nxos)# show ip route vrf management
No IP Route Table for VRF "management"
bdsol-6296-01-B(nxos)# sh run int mgmt 0
!Command: show running-config interface mgmt0
!Time: Fri Oct 16 11:02:50 2015
version 5.2(3)N2(2.23d)
interface mgmt0
  shutdown force
  ip address 10.48.43.82/25
Hope that clears things up.
M.
Marcin Latosiewicz
UCS/Fabric Interconnects are not routing devices. The operate either in end host or FC/Ether switching modes (the former being recommended for most deployments).
Hi Marcin
Thanks for clarifying. as per understanding from your update ip routing feature will not be available on fabric interconnect correct.
Thanks in Advance
Mohan.
Mohan,
interface mgmt0
  shutdown force
M.
Hi Marcin
Thanks alot clarifying detaily.Its makes me more sense.
Mohan.
