Nexus 1010 - No MGMT0 Access?
Hi all, I hope someone here can help!
I am setting up a Cisco Nexus 1010 appliance, but cannot access it through the MGMT0 interface!
What I am trying to do is copy over the 1000V .iso file to install a vsm, but I can not even ping the mgmt0 interface.
I have booted from the 4.2(1)SP1(3) iso, ran through the initial setup where I set the uplink type, domain id, vlan id and mgmt0 ip details.
Current config and sh tech attached
Let me know what other information I should post!
Kind regards, Ash.
12 Replies 12
More information re: my connection to mgmt0 interface:
1. Using the oob mgmt interface, not an interface from the 4 port PCI card or two ports underneath
2. I have connected the mgmt int to a switch in access port, with my laptop in same vlan in switch.  MAC table on switch learns from 1010, but no ARP.
3. I have connected direct to mgmt0 with both straight and cross cables to my laptop.
4. I have tried connecting to each of the 'uplink' ports.
5. I have tried all of the above after the Nexus has loaded operating system, and in switch(boot) prompt.
Hello Ashley,
On the rear of the Nexus 1010 are 7 ethernet interfaces.  1 for CIMC and 6 for N1010 communication.  Ports 1 & 2 are always used for management(mgmt0) traffic regardless of network-uplink type.  All six ports only support trunked interfaces; not access.  (In SP1.4 we do support native vlans).
Matthew
Thanks Matthew, yes I was confused thinking the CIMC interface was for mgmt0.  Trunking the uplinks I was able to access ok.
As an aside, which Vlans need to be allowed to the control/data and management interfaces?  I am assuming only the management vlan needs to be allowed to the management interface, and the control, packet and any vmware virtual machine data vlans should be allowed to the control/data interface?
Cheers, Ash.
Hello Ashley,
Since you are using network-uplink type 3, only the management vlan needs to be on interfaces 1 & 2.  On 3-6 all vlans used for control, packet, data (NAM) traffic need to be allowed.  These may be the same for the N1010 and VSMs, or different depending upon your configuration.  You do NOT need to allow virtual machine vlans.  Only mgmt, control, packet and data where data is the vlan NAM uses.
Matthew
emresumengen
Hi everyone,
I have a problem, similar to Ashley's in regards to reachability of N1010 in my lab...
I'm using network-uplink type 1 as it would be more than enough for my lab deployment. I have configured the CIMC and can reach/configure the device from there pretty easily. But, no matter how I try, I can't seem to get management access.
The N1010 is connected via it's Lom0 port to a Catalyst (at Fa0/10), which is configured as a trunk port. I'm using Vlan10 for all purposes...
The uplink switch has a configuration like this:
interface VLAN10
ip address 10.2.1.66 255.255.255.128
no ip directed-broadcast
no ip route-cache
interface FastEthernet0/10
description NEXUS_1010_TEST-LOM0
switchport trunk native vlan 10
switchport mode trunk
And the show running-config output from the Nexus1010 shows this:
!Command: show running-config
!Time: Tue Jun  5 21:21:59 2012
version 4.2(1)SP1(4)
no feature telnet
username admin password 5 $1$GW2TtGHE$oHUMu5em2..2XvSqJDlMb.  role network-admin
banner motd #Nexus 1010#
ip domain-lookup
ip domain-lookup
switchname N1010-ANK
snmp-server user admin network-admin auth md5 0xbc6feda9b778b02e324d11adda844e5c
priv 0xbc6feda9b778b02e324d11adda844e5c localizedkey
vrf context management
  ip route 0.0.0.0/0 10.2.1.126
vlan 1,10
port-channel load-balance ethernet source-mac
port-profile default max-ports 32
vdc N1010-ANK id 1
  limit-resource vlan minimum 16 maximum 2049
  limit-resource monitor-session minimum 0 maximum 2
  limit-resource vrf minimum 16 maximum 8192
  limit-resource port-channel minimum 0 maximum 768
  limit-resource u4route-mem minimum 32 maximum 32
  limit-resource u6route-mem minimum 16 maximum 16
  limit-resource m4route-mem minimum 58 maximum 58
  limit-resource m6route-mem minimum 8 maximum 8
interface GigabitEthernet1
interface GigabitEthernet2
interface GigabitEthernet3
interface GigabitEthernet4
interface GigabitEthernet5
interface GigabitEthernet6
interface PortChannel1
interface mgmt0
  ip address 10.2.1.40/25
interface control0
line console
boot kickstart bootflash:/nexus-1010-kickstart-mz.4.2.1.SP1.4.bin
boot system bootflash:/nexus-1010-mz.4.2.1.SP1.4.bin
svs-domain
  domain id 200
  control vlan 10
  management vlan 10
  svs mode L2
vnm-policy-agent
  registration-ip 0.0.0.0
  shared-secret **********
  log-level info
In no way I can access the mgmt0 interface IP from the network, or vice-versa.
The weird part is, I can see the Nexus in CDP neighbours, and I also can see the mac address of the mgmt0 interface on the switch (along with a correct IP assignment in arp table).
DemoSW#sh cdp nei
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
                  S - Switch, H - Host, I - IGMP, r - Repeater
Device ID        Local Intrfce     Holdtme    Capability  Platform  Port ID
N1010-ANK(1157310Fas 0/10           126         S I       Nexus1010 control0
N1010-ANK(1157310Fas 0/10           126         S I       Nexus1010 mgmt0
N1010-ANK(QCI1614Fas 0/10           126          H        Nexus1010 eth0
DemoSW#
DemoSW#sh mac-address-table interface fa0/10
Non-static Address Table:
Destination Address  Address Type  VLAN  Destination Port
0002.3d70.c800       Dynamic         10  FastEthernet0/10
0002.3d70.c801       Dynamic         10  FastEthernet0/10
0010.18cf.7886       Dynamic         10  FastEthernet0/10
36ce.bc88.c2d9       Dynamic         10  FastEthernet0/10
DemoSW#sh arp | incl 0002.3d70.c801
Internet  10.2.1.40               0   0002.3d70.c801  ARPA   VLAN10
DemoSW#ping 10.2.1.40
Sending 5, 100-byte ICMP Echos to 10.2.1.40, timeout is 2 seconds:
Success rate is 0 percent (0/5)
DemoSW#
Any ideas???
One thing that pops to mind is that the ports on the 1010 are Gig and you have the 1010 plugged into FastEthernet. The 1010 should auto-negotiate but you never know.
Do "show network" on the 1010 and make sure the ports are negotiating correctly.You may need to tweak the gig ports on the 1010 to connect at 100Mb.
louis
Actually, that was one of the things that came to my mind... But, the hardware installation document states all ports (both internal and pci) are 10/100/1000...
I can't confirm on the N1010 side (as it doesn't validate the command show interface GigabitEthernet1 or anything like that) but I can see on the switch side that the port is up.
And, as I said, I can get the correct mac address of the mgmt0 interface on the upstream switch. I can even get an entry in the arp table, with the correct IP address.
No connectivity though
PS: "speed" keyword is enabled under mgmt0 interface, but any command gives error ("ERROR: This command is not supported on this interface(s).").
On the 1010 what does "show network" say?
for example
cae-1010# show network
GigabitEthernet1 is up
  Hardware: Ethernet, address: 0026.cbc0.7922 (bia 0026.cbc0.7922)
  MTU 9000 bytes, BW 1000000 Kbit, DLY 10 usec,
  Encapsulation ARPA
  full-duplex, 1000 Mb/s
  Auto-Negotiation is turned on
    12540526 packets input, 1002730574 bytes
    3448863 multicast frames, 0 compressed
    0 input errors, 0 frame, 0 overrun, 0 fifo
    1775065 packets output, 360714346 bytes
    0 underrun, 0 output errors, 0 collisions
    0 fifo, 0 carrier errors
louis
Hmm, I guess you may be right... The 1010 seems to think it's connected to a GigE interface.
N1010-ANK# show network
  Hardware: Ethernet, address: 5057.a8af.7a78 (bia 5057.a8af.7a78)
  Encapsulation ARPA
    18159 packets input, 1167191 bytes
    18027 multicast frames, 0 compressed
    1720 packets output, 231195 bytes
Is there a way to set auto-negotiation (or speed manually) for the uplink ports?
No, the Nexus 1010 ports 1-6 are hardcoded at 1000. Only the CIMC interface is 10/100 capable.  I will get the hardware guide cleaned up.
Matthew
Hmm, that's bad, but thanks for the reply...
Hi Matthew/Louis,
I've switched the uplinks over to a 4948, and both sides are now running at 1000Mbps, but there's still no access from/to the mgmt0 interface...
Any more ideas?
UPDATE: After waiting a bit more, I can finally get access... Thanks everybody!
