PMON command not found
nagarajan.rao
The article says PMON stop and start would resolve the issue. But unable to locate the PMON command after connect local-management.
Could some one help please.
Naga
Wes Austin
Can you please confirm which article references this?
Let me start by saying that PMON stop/start should not be conducted unless in a planned maintenance window and/or you understand the health of the UCSM database. Pmon restart is harmless, as it just restarts management services on the FI, however, if you are in a non-healthy state, this could cause bigger problems.
UCS#connect local
UCS(local-mgmt)#pmon stop
UCS(local-mgmt)#pmon start
Please open a TAC case if you need assistance with this procedure.
Wes Austin
UCS#connect local
