Set vlan org permission
mike.paehler
I am working on deploying new VLANs to my UCS Central with the UCS Central PowerTool. Does anyone know how I can set vlan org permissions?
I know how I can set it on the console, but I do not find the cmdlet for powershell
Console command:
connect resource-mgr
scope org MyOrg
create vlan-permit dmz-vlan-1234
Mike
Wes Austin
Mike,
I believe this will help. This is how you can set the org permission. We will use "root/my_org" and "myvlan_11" as example:
Get-UcsCentralOrg -Level root | Get-UcsCentralOrg -Name "my_org" -LimitScope | Add-UcsCentralFabricVlanReq -Name "my_vlan_11"
You can also use the following tool to help you correlate actions in the GUI to cmdlets.
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/sw/msft_tools/UCS_Central/powertools/user_guide/ucsc_pwrtool_bk.html#pgfId-446548
HTH,
Wes
Wes Austin
Mike,
HTH,
Wes
mike.paehler
Hi Wes,
this worked for me. Thanks you very much!
Mike
