SNMP Traps and Monitoring UCS
oramirezm21
Hi Guys;
During the implementation of UCS Blades I found a number of issues that have not been solved. I need to monitor the UCS solution through a NMS with traps and monitoring certain items. To do this I require deliver the MIBS to the Monitoring group and tell the OIDs to monitor certain things but I dont found especific documentation about this. I need to monitor things like the states of the fans, cpu, memory and connections.
The solution consists of:
Fabric Interconnects: 2 x 6140XP
Chassis: 9 x 5108
Servers: 70 x B230M2
UCSM v1.4
Although i need apply certain security to SNMP like ACL to secure the solution in the Customer Environment.
8 Replies 8
padramas
Hi Padma;
Thanks for your response. But, how i find the OIDs especficis to monitor certain things? (for example status of the fans). I need to know especific OID to monitor.
Orlando,
Currently I am not aware of doc or tool that provides direct translation of UCS MIB objects.
OID for FAN inventory --  1.3.6.1.4.1.9.9.719.1.15.12
OID for fault table --   1.3.6.1.4.1.9.9.719.1.1.1.1
Alternate way is to load the MIBs and browse the table for required objects.
Padma
Hi Padma;
Thank you for this objects but i need more than this. Please send me a tool to find the UCS MIB objects or another one that have any usefull guide.
Orlando Ramirez
HI @oramirezm21
This the reference guide for UCS MIBs:
https://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/sw/mib/b-series/b_UCS_MIBRef/UCS_MIBRef_chapter_01000.html#reference_935B3C0D78E14A14B8D36FBD4A8D2883
Or go over the supported MIBs:
file:///C:/Users/SERGIU~1.DAN/AppData/Local/Temp/ucs-manager-supportlist.html
Based on the that, you can then go into the OID repository and see what OIDs are available in the specific MIB:
ftp://ftp.cisco.com/pub/mibs/oid/
Hope it helps,
Sergiu
What would be the OID of overall server status if i'm planning to monitor the status of UCS C240 M4S2
Hi @bobbywayne08569 ,
To locate any desired OID, go the supported MIB list by UCS C: ftp://ftp.cisco.com/pub/mibs/supportlists/ucs/
Or you can find additional details about the MIBs here: https://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/sw/mib/b-series/b_UCS_MIBRef/UCS_MIBRef_chapter_01000.html#reference_935B3C0D78E14A14B8D36FBD4A8D2883
Once you know which MIB contains the desired info, go and see all OIDs using this: ftp://ftp.cisco.com/pub/mibs/oid/
Hope it helps,
Sergiu
Hi Sergiu,
The MIB located support list shows only till  "Cisco UCS C-series software release 3.0 and later releases"
My current firmware is 4.0 will the 3.0 release MIB supports my version ?
