[SOLVED] How to Update expired certificate for UCS Web Interface
Hi all!
I have resign existing request for my UCS Manager and update certificate in KeyRing. But I don't know how to restart UCS WebServer to apply new cert. Can anyone help?
Tyler P
Step 1 UCS-A# scope security
Step 2 UCS-A /security # scope keyring default
Step 3 UCS-A /security/keyring # set regenerate yes
Step 4 UCS-A /security/keyring # commit-buffer
this will regen your keyring and clear the fault
-Tyler
May be this correct for self-signed default certificate, but we use CA signed certs.
I had fixed this with:
Via UCSM GUI (use IE, Chrome will not work correctly while cert expired):
0. Get and Resign existing request with CA
1. Upload signed cert to keyring and refresh browser to confirm that now keyring status changed from Expired to Valid.
Go to SSH:
2. UCS-A# scope system
3. UCS-A# scope services
4. UCS-A# disable cimcwebsvc
5. UCS-A# disable http
6. UCS-A# commit-buffer
7. UCS-A# enable cimcwebsvc
8. UCS-A# enable http
9. UCS-A# commit-buffer
After this refresh page in your favorite browser.
How to verify that the SSL certificate has been regenerated? Any show commands?
scope security
show keyring detail
In the 'not after: ' section should be date in the future.
Kirk...
