UCS ESXI VNIC FAILOVER ENABLE
eduardo.nunes
Could someone clarify what problem I may have with the following configuration, in my VMware environment I have two dedicated VM traffic vNICs and we are using the failover option inside UCS in VDS both vNICSs are active at first everything seems to work correctly, I always read that this is not a proper design for VMware but never speak of the problems that may actually occur.
AFROJ AHMAD
I don't think it is about the proper design , it is more of customer use case or scenario # NT.png
https://docs.vmware.com/en/VMware-vSphere/6.0/com.vmware.vsphere.networking.doc/GUID-73AB2E00-FE02-4D1B-970F-7D2F21F52825.html
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
