UCS FC feature Licensing Question
Hi All ,
Could you please let me know if we require licenses on the UCS system for FC Feature to work .  All I have in licensing screen is :
I  have pair of 6120's
ucsm-1-A /license # show usage
Feat Name                      Scope Default Total Quant Used Quant State
         Peer Status Grace Used
ETH_PORT_ACTIVATION_PKG        A           8           8          4 License Ok
         Matching             0
ETH_PORT_ACTIVATION_PKG        B           8           8          4 License Ok
         Matching             0
The FI is on Swithing Mode and is connected to a Nexus 5010 via an uplink port . When I do "sho flog dat" I do not see any entries .
Any pointers ?
The UCSM is in "FC End Host Mode" I hope (assume).
That being the case the FI will be operating in NPV mode.  You have correctly configured the Nexus with NPIV.  The Nexus 5010 interface should be operating in "F" mode (but auto should be fine also).
There will not be any FLOGI's until you have configured a UCS service profile with a vHBA for either SAN boot, or local boot and the vHBA on the Host OS is trying to access storage.  Have you done this yet?
A command you may find useful is issued from the UCSM CLI (ssh to the UCS Virtual IP)
connect NXOS
show npv flogi-table
If you don't see an NPV flogi entry here, you will not see it on the Nexus 5000.
Robert
Robert Burns
FC is not a licensed feature.  Licensing is handled by either the module purchase (6100) or by the impllcit usage of an interface (6200).
If you have a 6100 and purchase an FC capable expansion module, it will come fully licensed.
If you're using a 6200 with unified ports, each port is licensed for usage (either ethernet, FCoE or FC).
Robert
Thanks Robert ,
Any pointers on the problem I am facing here
UCS Port 2/1 (FC Uplink VSAN 100) --- Nexus 5010 FC 2/3
Nexus is NPIV Enable
nbnx5010-1a# sh vsan 100 mem
vsan 100 interfaces:
    fc2/3             fc2/4             san-port-channel 101 vfc11
    vfc12
version 4.2(1)N2(1)
interface fc2/3
  switchport trunk mode auto
  no shutdown
connect NXOS
Robert
Thanks a lot Robert , the FC was set to switching mode , changing to End Host resolved it .
