KVM launched via Java. since you already have java installed, save that jnlp file to somewhere in your management PC and double click it to open. (make sure file name ends with '.jnlp' extension, ex. viewer.jnlp) it will load the KVM. also use IE browser to access.
Mark this as solution and vote if this solved your concern.
KB
Please rate this and mask as answer, if this resolved your issue
Good luck
KB
