07-11-2019 02:48 PM
Which method i have to use to replace a faulty chassis in a UCS Mini deployment after to receive a new chassis for RMA??
It needs only to change the blades and fabric interconnects from the faulty chassis to the new chassis, or i have to take another task in consideration??
07-11-2019 06:55 PM
Assuming you are only replacing the 5108 chassis, and not replacing the 6324 FI/IOMs, then your configs should be retained.
As always, make sure you make backups of your logical, system, and full state, for worse cast scenarios.
Kirk...
07-11-2019 08:24 PM
07-12-2019 03:48 AM
If you are dropping the blades and FI/IOM modules into a new chassis, then you may have a new chassis # assigned due to the changed serial # when it discovers.
I believe you should be able to decomission the chassis, and edit the chassis # in while it is listed in the decomissioned tab be fore re-ack'ing.
Kirk...
