ucs question about major code F0283 and dce interfac and chassis number?
hailin huang
dear,
Introductions:
one 6120 connect  chassis 1 one 2104-1 and   chassis 2 one 2104-1
chassis 1 have sever 3/4/5/6/7/8  (all sever is B200 M3,two 2104)
chassis 2 have sever 1/2/3/4/5/7 (sever 1/2/3/4 is B200 M3,two 2104)
question
1.major code F0283
all server have  major code F0283 ,but all sever  still can use.what this? How I did it?
affected object:sys/chassis-1/blade-6/fabric-A/path-1/vc-722
description: ether vif 1/6 a-722 down,reason: unknown
i shutdown all ,and start the problem is also.
affected
2.on chassis 1 sever-1 adapter 1 dce interface (dce interfac 1 and dce interface 5)
ony one use?
3.
but i reboot ,
chassis 2 have sever 3/4/5/6/7/8
chassis 1 have sever 1/2/3/4/5/7
so the profile is disorder
i shtdown all,and start chassis 1 ok ,later chassis 2
the problem is ok..what this ?
2 Accepted Solutions
padramas
#1  F0283 - ENM source pinning failed
Please make sure the necessary VLANs that are allowed in vNICs are created in FI and and allowed in the uplinks.
#2 Link down errors
These are normal if the blades are not up and running with an OS ( with appropriate drivers ) .
Padma
David Alpizar
Hi Hailing,
The transport VIF for server is down.The Cisco UCS Manager raises this fault when any of the following scenario occur:
Endpoint(switch/fabric  interconnect) reports the connectivity state on virtual interface as  one of: a.down, b.errored, c.unavailable.
Verify  that the blade discovery was completed successfully. Check the states  on all of the communicating ports in an end to end manner.
If connectivity seems correct, recommision the server.
Also, please make sure you are using the correct drivers of the OS installed in the server as Padma recommended you.
I hope this helps.
David
padramas
#2 Link down errors
Padma
David Alpizar
Hi Hailing,
I hope this helps.
David
