Unable to boot UCS blade from SAN
Mohamed Roushdy
I am a newbe to Cisco UCS systems, I am an trying to boot UCS B200 M3 blade from SAN, ESXi was installed sucessfully, boot policy is configured properly (I suppoe), but it's not booting from it, I've even re-installed ESXi again, but didn;t boot eitther and goes into BIOS instead.
screenshots are available
Mohamed Roushdy
Hello again, I've fixed it, only one more step was required, from withing the BIOS setup, under boot settings, I've added a new boot option pointing it to <BOOT>, it's very simple try it.
I can also share screen shots if required.
Thank you,
5 Replies 5
Mohamed Roushdy
Thank you,
Can you share the screenshot  ? Thanks!!
hi,
I have the same problem, can you explain me how you did for the resolution ?
I had same issue and these steps worked. I could manually boot to CIMC CD and reinstall VMware, and it would see the ISCSI LUN (NetApp) but the blade wouldn't boot to it. If I booted to a boot menu my only option was EFI or the CIMC CD, if mounted.
Still no explanation why the boot policy isn't taking effect. My system is on version 4.0(1a). My next step is going to be to blow away the service profile and recreate.
Boot the blade into BIOS (press F2 during boot)
Go to Boot Options Page
Go down to Add New Boot Option
Press Enter on Add boot option to give it a name.
Go down to Path for Boot Option
Select one of your ISCSI LUNs
Press enter on EFI
Choose <BOOT>
Choose BOOTx64.EFI
I wound up Reapplying the configuration which solved my issue. Hope this helps someone in the future.
