Using a Wildcard Certificate with UCS Manager/Central/Director
Joe Baldwin
I'm trying to figure out if its possible to use a wildcard cert with UCS Manager, Central and Director.
I've searched the web and not found anything but thought I'd check in here before opening a tac case.
Cheers
Joe Baldwin
I contacted Cisco in the end.  It appears Wildcard certs aren't supported at all (Coming later)
Central only supports self signed:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCuh06347
I'm still waiting for a responce for Director.
I see this post is almost 8 years old.  You mentioned wildcard support was coming later according to TAC.  Have you (or anyone else reading this) been able to make this work yet or is it still unsupported?
Yeah, this would be great to know if wildcard support has been added to the UCS Manager.
