Zoning, direct attached Netapp
Walter Dey
UCS V2.2.1b, FC switch mode, Netapp filer direct attached with FC.
SP with 2 vhba, one mapped to fabric A resp.B., 2 FC target end point, one in fabric A, resp. B.
If I check the zoning done by UCS, I actually see 4 zones (SIST) ? why ? I would only expect 2 ??
Manuel Velasco
The additional zones get created because of the wwpn targets added in the boot order policy. If you remove or add more targets it will add or remove additional zones
