5350 Help
dconstantino
Level 4
Level 4
I need help with a design issue. I work with call manager and small voip gateways and this is the first time I have worked on a 5350.
I have a Sonexis conf device with a pri in it going out to the PSTN I want to direct connect it off of the 5350 so IP calls can also access it. I have attached a drawing to help with the topology.
Notice in the drawing that the 5350 is direct connected in to the Soneis to leverage both the IPWAN and PSTN. Any help would be great.
amritpatek
Level 6
Level 6
Check this out for the various design guides. It has the Cisco recommendations for designing voice solutions for small and medium businesses.
Design Guides
http://www.cisco.com/en/US/netsol/ns339/ns395/ns359/networking_solutions_design_guidances_list.html
